Had hood open to work on something. Disconnected light under hood by unplugging the socket. When I reconnected it, I pushed it in backwards and heard a little pop. Now I have no dash lights, A/C or rear Wiper. Fuses check OK. Any ideas??
thx
Check fuses and relays ----re check your fuses and relays as well as battery block and ground straps if all good will need a meter to back trace and search for possible wire short or melted wiring in harness
repairpal.com > Questions > GMC > Jimmy > 1997 GMC Jimmy
Jan 11, 2011 - hi about 2 days ago i realized my brake lights were not working but my turn signal lights were working and parking lights as well but no brake ...
Sep 23, 2009 - 97 GMC Jimmy 4x4 blinkers work, reverse lights work, above window ... I just lost hazard lights and rear brake lights, they were working 2 days ... If it is a frayed wire or solder point, then you can repair it, but not any worn contacts. ... Does anyone have any suggestions on 1997 Honda Accord tail & brake lig.
u need 2 ppl one to pull latch one to pop it on at hood once opened both should pull up on broken side til both side pullable then having something to hold it wouldbe good
under hood in panel box.First try this, push and hold brake pedal while pushing on and wiggle the hazard switch if brake lights come on then replace the turn signal switch and you will have brake lights.
The best thing to do is scan the computer for codes, if its not shifting correctly then the check engine light should be on, autozone parts store will scan it for free, these codes will help in finding the problem, it may be a bad speed sensor or something like that, start with the scan first.
I have notice that this is a common problem. The socket most of the time goes bad, I don't know why but they just do. You can pick them up at any parts store for around 5.00 each. If you don't have a volt meter and ground straps to test it right, then I would try changing the sockets out. Quick and easy. Let us know how it goes.
where are the relays and how do you check them?
