Question about Jura Capresso Impressa S8 Coffee Maker, Espresso Machine
My Capresso s8's display is blinking and making strange noise
My Capresso s8's display is blinking between coffee ready and tea portion and makes noises every time. I cannot get it to stop. I've tried moving the dial to tea portion and back to the cup. I've unplugged it and kept it off for a while. Nothing is working.
Posted by Patricia Bordoni on
Edward Harris
    Scholar:
    New Friend:
  • 78 Answers
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Posted on Oct 23, 2016
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: capresso s8 weak coffee
You should probably run a cleaning cycle with a cleaning tablet (the one you drop into the ground coffee shoot, not a decalcifying tab).
This will clean out all the insides where coffee particles and oil can accumulate.
The machine will ask you to run a cleaning cycle after a certain number of cups brewed. But you can also manually start it.
(this is copied from the manual)
You can run a tablet cleaning cycle at anytime even if
the machine does not prompt you,
• READY. Push and hold the Rinse button until display shows
RINSE. The Dial illuminates.
• Turn the Dial until display shows CLEANING. Push the Dial.
Display shows EMPTY DRAWER.
(Follow the rest of instructions for regular cleaning cycle)
Posted on Feb 21, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: my jura capresso says system fill...it makes a lot of noise
System fill is usually when the machine auto solenoid fill valve is putting water into the boiler. If it is making noise then the solenoid is clogged or there is no water getting to the solenoid.
Posted on Jun 18, 2009
Morten Bergendahl
  • 60 Answers
SOURCE: My Jura Capresso coffee maker is
The sieve in the brew unit is probably clogged, this means that it takes to long to push the water through the coffee. There is an automatic time-out on the pump that controls this. It also can be that your coffeeoutlet is clogged.
Try cleaning out any used coffeegrounds from the inside of the machine, use your finger up into the brew unit. If this doesn`t help, it needs service.
Posted on Oct 06, 2009
RB5193
  • 4 Answers
SOURCE: Tray empty message
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
Bob Keast
SOURCE: My Jura Capresso Impressa E8 is leaking water
I have the same problem with my E9 and I have traced it to the diaphragm unit that is just distal to the pump itself. Apparently, the diaphragm is secured with a steel band (not stainless since it is rusty) that may hold seals or O-rings that break down. You can observe it leaking when pressure applied during brewing. The question is: can a new unit be ordered and if so, where?
Posted on Nov 05, 2011
Jura impressa s8, the display shows" please wait" and doesn't switch to the Coffee Ready.
This error is because:
1- Flow meter is blocked & not sending signal of water flow.
2- Entire hydraulic system is filled with Calcium deposits and slowed down flow of water.
Solution:
1- Open the machine and manually clean flow meter. It is located between the water tank & the pump.
2- Follow this by manually descaling the machine. Seelink. Do not use automatic descaling method suggested by Jura.
Stop using Filter cartridges as the machine reminders for descaling are silenced by use of filters. Services Unlimited Inc Parts Guru Since 1988
Apr 22, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Fother not working
Clean it with a paper clip or pin
Nov 02, 2014 | Jura Capresso Impressa X90 Espresso...
Makes grinding noise then Malfunction 8
Jura Capresso E8 Makes a cup of espresso then makes a gear grinding sound and then throughs an Error * on the screen. Machine was repaired by Capresso a year ago.
Oct 27, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
Sep 13, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
My jura capresso says system fill...it makes a lot of noise
Jun 16, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Capresso s8 weak coffee
Jan 16, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso Impressa S8 Coffee Maker, Espresso Machine Logo
154 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
