Question about Sharp MX-2700N Color Copier
Please how can i correct the code f2-41 on my sharp mx 2700n photocopier?
Ngoro
    Top Expert:
  • Sharp Master
  • 2,608 Answers
please how can i correct the code f2-41 on my shar - please-correct-code-f2-41-sharp-mx-2700n-spy0qcsu1t10rbhc0w1yvmbc-1-0.png
Posted on Sep 24, 2016
5 Related Answers
Anonymous
  • 115 Answers
SOURCE: Error Message H5-01
H5-01 = detecting 5 consecutive POD_1N jams
Check the fusing section for jam paper. (winding, etc.)
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for
input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
To fix this you need to have the fusing unit looked at... could be various problems causing this , from bad paper to bad rollers?
Posted on Nov 24, 2008
Anonymous
  • 24 Answers
SOURCE: error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Posted on Dec 01, 2008
Anonymous
  • 143 Answers
SOURCE: Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
Posted on Aug 01, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: What do it do to fix ''maintenance required Code: CA''
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Posted on Aug 02, 2009
rezazadeh
abbas rezazadeh
  • 328 Answers
SOURCE: Sharp MX-2700N how can I clear maintenace code CA?
enter code 20-1 start
Posted on May 27, 2010
What shall i do to return my sharp mx-2700n copier to operation?
have you check the sensor actuates on the registration section
Oct 19, 2015 | Sharp MX-2700N Color Copier
How do I print to the MX-2700n?
If you are conecting directly you should be using a usb cable and you will need to install print drivers from sharp usa.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Aug 29, 2014 | Sharp MX-2700N Color Copier
We have a code h4-30 on a sharp mx-2700n how do I reset?
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jul 07, 2014 | Sharp MX-2700N Color Copier
Error code u2-10 on a sharp mx2700n photocopier
U2-10 SRAM user authentication index check sum error. I know, gibberrish right? To clear this error, put the machine in "simulation mode" by pressing "c" "*" "p" "*". then type 16, press the copy button, then press "execute" then press "yes". Hit the "ca" button to go back to ready. This should clear the error code. If the code returns, then the PCU PWB board needs to be replaced. I hope this helps.
Jan 27, 2011 | Sharp MX-2700N Color Copier
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
Call for service: code U2-05
i think that u2 shows some memory or eeprom problem just reset it .press clear key,exposure mode key,clear key,exposure mode key,press all these key in sequence and quickly.display will go dead now press 16 then start key.code will bi removed .mian jee
Jan 16, 2009 | Sharp MX-2700N Color Copier
Error code h4-01
Dec 01, 2008 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
176 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
