SOURCE: Fax problem
I had the same problem! You have to set your fax machine option to DRPD mode. Menu, to Fax setup, to DRPD mode, press ENTER, ENTER again, it should say waiting ring, you then have to call your fax line. Back to Fax Setup, Recieve Mode, press DRPD mode. This way your machine well distinguish a different ring for your fax.
SOURCE: problem scanning with samsung scx 4521f
My connection is via a parallel to parallel cable, and I am also having a similar problem. I'm reading that usb to usb cable is the only way it will properly function. good luck with it!
SOURCE: ERR UN FUSAO CRU - SCX 4521F
Eu tive o mesmo erro, e foi quando eu troquei o cartucho de toner. Deve ser um problema no fusível do cartucho, porque quando retirei o fusível e deixei sem o mesmo, a impressora voltou a funcionar normalmente. Agora estou providenciando um fusível novo para substituir.
SOURCE: how to set fax confirmation on Samsung SCX-4521F
Link to download manual for instructuions:
http://www.samsung.com/us/support/download/supportDown.do?group=printersmultifunction&group_cd=&type=printersmultifunction&type_cd=06010000&subtype=monochromelasermultifunctionprintersfaxes&subtype_cd=06010300&model_nm=SCX-4521F&dType=D&mType=&model_cd=SCX-4521F/XAA&menu=download&menuLink=/support/download/supportDown.do&prd_ia_cd=06010300&disp_nm=SCX-4521F&isEqualsY=
SOURCE: Samsung SCX-5421F Laster Printer crashes my pc
Have you tried uninstalling and re-installing the software. Perhaps there is an updated driver for your system since you first installed it, or maybe yours is simply corrupted. I would suggest removing and reinstalling will solve the problem - if, in fact, that is your problem -I've not heard of this happening before.
Drivers are here if you need them:
http://www.samsung.com/ca/support/download/supportDown.do?group=printermultifunction&type=printermultifunction&subtype=monochromemultifunction&model_nm=SCX-4521F&disp_nm=SCX-4521F&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&model_cd=&menu=download
