SOURCE: Frozen slabs of ice instead of ice cubes
the icemaker could be leaking by can you see where the water is coming down into the bin from??
SOURCE: Ice maker makes hollow ice! Why?
Not getting enough water into the ice maker. Could be a partially frozen supply line, restricting the total water input, or it could be that the timer needs to be adjust.
If the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
To adjust the timer, follow the instructions here http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
SOURCE: kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
SOURCE: Kitchen Aid KSCS25INSS ice making replenishment
There could be many reasons for this problem. Because you said the ice maker stopped with ice in the trays leads me to focus on the ice maker alone. I will try to get some photos and links when I return. Sea Breeze
Testimonial: "I appreciated the to find and relay useful information along with effort to insure it was easy to understand"
