Frigidaire AEQ7000EG Affinity Series Electric Dryer Logo
R
Rick lawson Posted on Sep 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dryer is not heating
The dryer will run but does not heatup
BOB LEA
Level 2:
Guru:
  • Expert 62 Answers
  • Posted on Sep 22, 2016
BOB LEA
Expert
Level 2:
Guru:
Answers
62
Questions
0
Helped
15430
Points
257
THE PROBLEM MAY BE OF SEVERAL THINGS
1. ELEMENT BURNT OUT
2. THERE ARE NORMALLY TWO TEMPERATURE STATS
ONE CONTROLS THE TEMPERATURE/ SWITCHES THE HEATER ON AND OFF AND THE OTHER IS A OVER TEMPERATURE STAT, IF THIS TRIP'S IT WILL NEED REPLACING AND ALSO THE WORKING STAT, THAY COME AS A SET.
3. WIRING CONNECTION ON HEATER ELEMENT BURNT OFF
4. PROGRAMMER CONTACT /CABLE PROBLEMS
MAY BE CHEAPER TO BUY A NEW ONE AROUND £200
GOOD LUCK
Inclusion dryer won't heatup
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 05, 2015 • Dryers
I Checked thermostats heating element and fuse and all is good and it still wont heatup
what's the model number?some dryers have even heat boards and relays also in them.one more thing when checking parts for continuity you have to pull off at least one of the wires to read out your part,if all checks goodyou could have a bad timer or board depending on your model or a bad motor,broken wire.the only way to tell is to check with a meter first for continuity and then with power on to see if 240 volts is coming first to the dryer and then to the heating element. but send the brand name and model number so someone can help you out.
Jan 11, 2014 • Dryers
When we try to dry the clothing, the gas dryer will not heatup and the timer knob does not advance. It does this on all the cycles.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Kitchenaid gas dryer model # kgye800swh1 starts, but does not heatup
heatman101
Dryer runs but does not heatup
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
MY DRYER TURNS ON, AGLOW IS VISIBLE IN THE FRONT OPENING, WARM AIR IS FELT AND THEN GLOW GOES AWAY. no heat is produced?
That tells me you have a lint build up in the dyers exhaust vent tubing. Clean out all obstruction by removing the entire duckwork and reinstall. Then it shall heatup like it was new again. A moister sensor detects any clogged areas and puts the burner into a check mode stopping the heating process. It was manitory a decade ago so it will prevent home fires in dryers
1helpful
Dryer doesn't heatup
SOUNDS LIKE THE HEATING ELEMENTS ARE BURNT OUT, I WOULD ALSO SUGEST YOU REPLACE THE TERMOSTATS.
Nov 01, 2009 • Dryers
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
