Coffee Makers & Espresso Machines Logo
Antonia Cacciotti Posted on Sep 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The grinder works but coffee too light in colour and no foam
How con I get a nice espresso with foam?
Kelley Hopper
Level 2:
  • Expert 67 Answers
  • Posted on Sep 23, 2016
Kelley Hopper
Expert
Level 2:
Answers
67
Questions
0
Helped
33891
Points
172
You didn't indicate what model you are using but it could be several things.
If your coffee isn't ground fine enough your brewing time may be too short. Your double espresso shot should take between 18-26 seconds to brew. A single should take between 9-13 seconds to brew.
If you are getting the correct brew time, try a different coffee bean. Some coffee is roasted more that others and that could be the reason the color is light. Make sure you are using fresh beans too.
Make sure you are putting the correct amount of ground coffee into the porto filter and tamping it well. A porto filter that isn't full will not brew a good shot.
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Not fine enough grind
This model grinder won't do espresso. There is a DIY mod available online that involves disassembling the machine, and recalibrating the burrs to produce a finer grind. I did it on mine, it was definitely better, but it's not going to get you to the coveted 30 second pull for your espresso. Search on Starbucks Barista Grinder Mod. It is a great grinder otherwise, very reliable.
How to use the astra coffee espresso
Hello there:
here is a couple of links that will help you get the right manual that you need ok?
best regards michael
  1. CoffeeGeek - Espresso: Espresso Machines, Astra Boiler Level Control ... i got the user manual, and a parts list from Astra, and am attempting to ... Expertise: I love coffee. Espresso: LM GS3. Grinder: Mazzer. Vac Pot: have one. Drip: no ...www.coffeegeek.com/forums/espresso/machines/407128 - Cached
  2. CoffeeGeek - Espresso: Espresso Machines, need help understanding my ... Astra recommends a particular type in their user manual, but there are better ... Expertise: I love coffee. Espresso: Astra Pro. Grinder: Macap M4 & Digital M4, BV ...coffeegeek.com/forums/espresso/machines/378621 - Cached
  3. Espresso Grinders Coffee machines, Grinders,parts, Slush machines ... HGS007 Astra home espresso grinder with timer for direct ... MDF manual. MDF Exploded diagram. Virtuoso Conical Burrs Espresso Grinder. Virtuoso user's manual ...saecoparts.com/EspressoGrinders.html - 235k - Cached
  4. Astra Espresso Machines Espresso machines, Grinders, parts, Slush ... Astra Mega III Manual rocker switch dosing 220V 5500 Watts 18 liter boiler ... All Astra machines operate with ground coffee and / or pods interchangeably - no ...www.partsguru.com/AstraEspressoMachines.html - 162k - Cached
Looking for a way to unjam my grinder
If you look at the grinder parts you will see a little red mark, take the parts you lift off the grinder and put it back, turn it clockwise to the red mark is align. You have to press the adjustment pin to turn the grinder parts.
Have a nice day
/Mirran
Saeco coffee espresso machine Type SUP 018M At the beginning, the amount of water, was lower than what it should be. I had to set the machine on the large cup side, to get the amount of water for an...
Make sure you not get any water in the grinder. If you not get any water in the grinder then it can be the micro switch that has to be replaced.
You can program the button for how much coffee you will have, press and hold the button, when you reach the level you want then release the button.
let me know if you get your machine to work.
Have a nice day
/Mirran
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Top Faema Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
