Question about Nokia N70 Cellular Phone
Problems n70 TOMTOM
Hi, i'm trying to use TomTom with my N70, but during my trip in continue to disconnetc from the Blurtooth antena. This problem in my country is very
Widespread. thanks a Lot
Posted by Tonino on
  • 1 more comment
  • Anonymous Dec 07, 2007
    where can I get my nokia n70 blue tooth remote software
  • Anonymous Feb 28, 2008
    my nokia n70m is hanging very often
    same problem
Anonymous
Use this code *#3370#
Posted on Apr 08, 2008
Anonymous
Teri maa ki chu6t
Posted on Apr 10, 2008
Anonymous
  • 4 Answers
Nokia n70 outo on of problem how can solve this problem..please nokian70 manual formating code please
Posted on Dec 15, 2007
Weak signal n70
check pad of antena, maybe antena pin on board not touching to antena pad, clean if necessary.
Aug 03, 2010 | Nokia N70 Cellular Phone
My Tomtom 130 GPS seems to be frozen.
Hello there:
first off i would consult the troubleshooting section in your users manual if you dont have it contact the manufacture of the device for a manual.
otherwise try this remove the power cord and press and hold in the reset button for 2 min this may help reset the unit.
If not remove the power cord and leave the unit sit for several hours it has a re learning function built in also if you can go to www.tomtom.com to view a downloadable users
Aug 05, 2009 | Tomtom ONE 130 GPS Receiver
Can't get passed the searching for streets...
OK! I'll help you! read this fast! :)
I have a tomtom too, and it sounds like the map files are corrupt, it should have come with a CD, you need to plug your tomtom into your computer with the given USB, and turn on TOMTOM HOME. You'll then need to go to "Back up and Restore" and restore your tomtom to the factory settings! Also you might try to push the very small reset button located in a little hole somewhere on the device, you'll have to hold it down with a pin or something! THAT MAY WORK... but i know for a FACT that the restore WILL.
ALSO, if you dont have TOMTOM HOME, you can download it HERE: http://www.tomtom.com/services/service.php?id=16&tab=87
Hopefully this helps!!! :) Have fun on your trip!
May 27, 2009 | Tomtom GO 720 GPS Receiver
Tomtom one won't connect to computer
I tried to download the update and now my is stuck. During installation it was supposed to download 7 components but it quit and gave an errorand could not continue the download. Now whenI turn it on it keeps looping to the tomtom main screen and telling me some legalities, and states it cannot find a gps signal.
I wish I could have the version that camewith it. There should be a op for me to restore it to factory default.
I don't advise updating the software at the website, it worked great at first.
Apr 08, 2009 | Tomtom ONE GPS Receiver
Light on top indicates power is on but nothing showing on screen
Hi, try a reset ( push paperclip into hole underneath tomtom ) . if the reset doesnt work then its likely your charger might be faulty and putting too much voltage out and has damaged your tomtom . ( quite common ) .
Good luck .
ps , I have posted solution to this problem many times so it might be worth reading / looking through my other posts .
Dec 31, 2008 | Tomtom ONE GPS Receiver
Frozen tomtom go 910
Hi, Not a nice problem that. Try connecting your tomtom to PC ( not through home ) so the tomtom will look like a USB drive in "My Computer". if TomTom Home tries to load up , cancel it. Look in "My Compuer" If you do see the TomTom as a drive , open it up and copy the folders and files to your PC. If that works, now you have a backup and you can have a mess around knowing that if you mess things up , at least you can put things back as they were and you won't have made anything worse than it was before. Once thats done , try a harder reset in normal way but also hold the ON button in whilst doing the reset . Many people press too hard on the reset button and also hold it too long so just give one single press , only hard enough to feel it click in , then out. Thats all it needs for a reset and it avoide damaging the switch ( yes , I have seen many reset switched stuck in or broken ). I think theres 2 possible causes for your problem . 1/ You now have a corrupted file on your TomTom preventing the boot-up continuing. 2/ Your Tomtom is still trying to perform the last function ( backing up through TomTom-home ) and has somehow got stuck in that loop. For the moment , try the above and see how you get on and if you donn't solve it please post on this forum again .
Good luck .
Nov 12, 2008 | Tomtom GO 910 GPS Receiver
I am going to Hawaii from my home in Sydney Australia and wish to down load the maps from Hawaii so that I can use my TomTom during the trip. How do I go about getting the maps? Bernieh
over here
http://www.tomtom.com/products/maps/
Traveling abroad?
If you are visiting another region or country but do not have the map pre-installed on your TomTom device, simply get an additional map and you’re set to go.
click the goto map shop link on the page.
Oct 19, 2008 | Tomtom GPS
Tomtom on n70
PLEASE GIVE SOME SECRET CODES OF N70
May 13, 2008 | Nokia N70 Smartphone
Need a activation code for tomtom
format the memory card from pc.
Jan 09, 2008 | Nokia N70 Cellular Phone
Need help to get a activation code.
The right way is to buy the code from where you purchased the Tomtom.
Nokia N70 Cellular Phone Logo
124 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
