Red light on mouse was blinking. I changed batteries, and now optical mouse will not move the screen icon. I can move the icon using my laptop, but cannot get optical mouse to function. I have double checked battery orientation, and that is correct. mouse turns on and off, and the optical blue light on the mouse comes on, so it appears okay. Just cannot get it to move screen icon,as it did before the battery change. any suggestions?
SOURCE: Dell wireless mouse is blinking red, but functions. Problem?
try to rest the connection by pressing the connect button on the reciever and under the mouse together and relaesing them. it should work
SOURCE: Mouse doesn't work
LOOK FOR A BUTTON TO RESET THE MOUSE AND THE USB CONNECT SHOULD ALSO HAVE A RESET SWITCH ON THE USB CONNECT YOU NEED TO PUSH BOTH AT THE SAME IME SO THE CAN GET INSINK OR THE CHANNEL TO SET. SOME TIMES THE MOUSE HAS TO BE TAKEN APART AND CLEANED JUST LIKE THE OLD MOUSE BALL ONE, AND RESET THE MOUSE SETTING IN CONTROL PANAL, UPDATE DRIVE MAY ALSO HELP IF THERE IS ANY NEW FIXS
ROD
PS SOME TIMES THE LEAD TO THE BATTARY CONNECTION NEED THE THE SPRING PULLED OUT A LITTLE OR THE OTHER END WITH METAL TAB ON IT NEEDS PULLED OUT BECAUSE THE PLAY IN THE BATTERY COMPARTMENT IS LOOSE AND THE CONNECTION IS INTERMITTING A VOLTAGE CHANGE AND CAUSES THE MOUSE TO LOOSE ITS SIGNAL TO THE TRANSMITTER OR SET FREQANCES.
ROD
SOURCE: Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
SOURCE: Help me make this wireless mouse work!
I had the same problem and after hundreds of tries i push the button on the receiver and quickly the red connect button on the optical mouse for about 5 seconds and it work... i don´t know if it´s a final solution but this time it work´d
SOURCE: Optical wireless mouse HP worked the first time
I had faced the same issue, it has nothing to do with a battery. Please refer to the The mouse or keyboard does not work at all at the website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00006821&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN#N56 and the same should resolve the issue - follow the instructions in details.
