Question about Kohler Electrical Supplies
I have a Kohler 7.3 ECD generator with error code UVunder frequency. Restarted gen and it ran for one hour so I shut it off. What's the problem?
Error code UV
Posted by Ron Smith on
Bill Boyd
    Top Expert:
  • Kohler Master
  • 53,816 Answers
Check the operating rpms
the rpms determine the voltage and frequency and can be adjusted at the governor spring setting
adjust it until the voltmeter reads the required voltage
set slightly above to allow for rpms drop under load
for example if 240 volts set around 250 volts and that will drop back to 240 volts under load
if 110 set around 115 and that will drop back under full load
both frequency and volts are dependant on rpms
Posted on Sep 21, 2016
Error code 0b0004 00000011
-Check that the cable from the Ink Supply Station (ISS) PCA to the Ink Supply Station is correctly connected.
-Faulty APS. Replace the APS (See Air Pressurization System (APS)).
-If the error code continues, replace the Main PCA.
Apr 03, 2015 | HP Designjet 5000ps 60-inch/uv/postsc...
I programmed my Baofeng UV-5R to a UHF repeater frequency and entered the proper CTCSS code. I also correctly entered the correct offset which allows me to connect to the repeater. Howerver, when I
Please. Your question got truncated in the title, and was not asked in the details. So I have you asking, "However, when I..." and that this is occurring on your UV5R. Please respond with details and I will try to help you. I own the UV5R+.
There is an excellent owner's manual for the BaoFeng at Miklor.com/uv5r/userguide.
Apr 02, 2014 | Baofeng UV-5R PlusEarphone...
Which is the better radio uv - 3r dsp or the uv - 5r
the uv-5r have more powre on transmit and more chanals to program uv-3 (99) AND UV-5 (128chanels)
Jun 24, 2013 | Baofeng UV-3R Plus 136-174/400-470MHz...
How to fix error code 6102 develop ineo +200
Q10. In layman's terms, resveratrol is one of the many ingredients that can protect our systems in the harmful impacts of pollution, UV light, air, nitrogen and moment.
http://www.trueplusgarciniatry.com/alpha-f1/
Nov 26, 2012 | Konica Minolta Office Equipment & Supplies
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
After converting our 60" HP
Have you tried to revert back to the dye inks?
If that solves the problem, then your UV ink tubes have a bad control board.
(you did change the ink tubes system, printheads and ink ?)
Jul 19, 2011 | HP DesignJet 5500PS InkJet Printer
Does anyone know what E 45 error code on the philips PU 8600 uv/vis refers to?
HI Barry, I'd be grateful for information on this fault. [email protected] thanks in advance.
Feb 04, 2011 | Kitchen Ranges
The UV-visible spectrophotometer(Cary 100 Bio, Varian company) in our lab is now showing faulty error while starting the instruments. It says Error Code: 9:9330SEQ:E9330, chopper not upto speed. Where to...
May be that your deuterium lamp for UV or possibly tungsten lamp is out or misaligned. Ran into something similar several years ago. The UV lamp initially ignited but shut down a short time later ( less than a minute) since there was not enough intensity being detected. The error message was similar.
Sep 30, 2010 | Kitchen Ranges
Electrical Supplies Logo
358 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
