Question about Daewoo FRG1820BRW Top Mount Refrigerator FRG1820BRW
Location of a parts store to buy a new door seal for daewoo model frg1820brw fefrigerator
Posted by ronald g baker on
john h
    Top Expert:
  • Daewoo Master
  • 23,590 Answers
Do a search in your area for appliance repair shops or online search for a daewoo door seal with model number
Posted on Sep 20, 2016
Where is the camshaft sensor located on 2002 800cc Daewoo Matiz?
When you go to parts store to buy the part, they have component location charts that may help you. You know it will be near the camshaft, and often at the front. You might want to just buy a cheap shop manual for full instructions for this and so much more.
Oct 18, 2016 | Daewoo Matiz Cars & Trucks
Why is it icing up and will not cool?
You have a defrost problem and you are correct in one of those things being bad. Once you ohm them out and find out which one you can go to you tube to get a video on how to replace and how to ohm them out. Good Luck!
Jul 28, 2015 | Daewoo FRG1820BRW White Top Mount...
Where can we buy new door seals
Hello;
My name is Peter. I am a retired field service appliance technician.
New door gaskets need to be soaked in hot water for 30 minutes before mounting to allow for forming.
Some door gaskets are a tang and groove and easily installed others have sections of backing plates and about 32 screws to remove and mount.
Door gaskets are expensive.
Go into the following website and put in your model number, which is located on the upper inside wall of your fresh food section. You will see diagrams with part numbers. Copy the part numbers and go into the internet and search best price.
Water Filters Lawn Garden Appliance Parts
May 07, 2015 | Refrigerators
I need a wiring diagram for a Daewoo fridge/ freezer frg 1820brw, any idea where I can get one?
check repairclinic.com - they have a lot of repair info, some online, as well as some repair videos.
Nov 26, 2014 | Daewoo FRG1820BRW White Top Mount...
How to change camshaft seal on a 2000 daewoo lanos
The OP asked how to replace the camshaft oil seal. The suggested answer talked about replacing the timing belt, which is part of the procedure, but not the seal. My auto parts store suggested a thorough cleaning with carb cleaner and then using high tack adhesive or gasket sealant to make sure the seal stays put. I would also like a rundown on R&R of the seal.
Jan 04, 2014 | 1999 Daewoo Nubira
Is FRG-1820BRW frost free
Most of the newer models are all frost free.
Nov 22, 2012 | Daewoo FRG1820BRW White Top Mount...
Hi, I have a whirlpool refrigerator model WRB101.
If a new seal is needed then you can call any appliance sales store and they an order one in for you with the correct information, or you can call the manufacturer of the fridge and they have a parts line you can order your parts directly from them. Good luck
Sep 08, 2012 | Whirlpool Refrigerators
Where is the Thermostat located for my heater in my 2001 Daewoo Leganza?
On the engine block at the end of the upper radiator hose inside the housing. It comes in the housing when you buy it from most auto parts stores.
Sep 25, 2010 | 2001 Daewoo Leganza
Frigidaire dishwashers FDB2810LDC0 bottom of door leaking where do I find a new seal?
You can obtain a new seal through an appliance parts store. You will need the make and model number of your dishwasher to get the correct seal.
Oct 03, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Daewoo FRG1820BRW Top Mount Refrigerator FRG1820BRW Logo
180 people viewed this question
Top Daewoo Refrigerators Experts
Lawrence Oravetz
NOEL
NOEL
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
