Question about Samsung PN42A450 Plasma TV
Hello , my name mike I Have a samsumg 42 inch plasma model pn42A450p1d . Picture looks good other than left side has a 3 inch black section from top to bottom. Any help
Posted by Marco garcia on
  • Marco garcia
    Marco garcia Sep 20, 2016
    Upon reading all comments on here sounds like a common problem with buffers . I am gonna try to check connection and clean with duster . Also if I solder will it hurt ?
    Top Expert:
  • Samsung Master
  • 76,407 Answers
Hi, My name is Amp:
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Sep 21, 2016
5 Related Answers
Anonymous
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
Anonymous
  • 7 Answers
SOURCE: 42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Posted on Jun 07, 2008
roety
Eric Rotmil
  • 587 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 19, 2009
Anonymous
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Posted on Nov 10, 2009
roety
Eric Rotmil
  • 587 Answers
SOURCE: I have sound but not picture on a Haier plasma tv
Hi my name is Roety,
I can help you with your issue ,
These Haier TVs go bad and I always install the repair kit part #?TV-3940-01
It includes the scan boards and an upgraded IC .
I can not find any kits in stock, but I know there some available online if you search or call a few places.
Mat electronics or sears parts direct may have some.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Apr 14, 2010
Testimonial: "this is very helpful,I will try it and let you know. NAVARRO"
Picture covered with big block of black - 3/4 of the screen ???
It sounds like your tv may require a plasma panel, but to be sure remove the back of the tv unit and check the y-sus printed circuit board as well as the z-sus printed circuit board, check that they are getting the correct voltage and that there are no blown compoments on the boards themselves. The boards names, z-sus and y-sus are written on the board as well as the voltages are listed down the side of where the plugs at the boards meet. Good Luck. Oh , and also, check with LG that it doesnt require a software upgrade.
Dec 02, 2009 | LG 42PX5D 42 in. Plasma HDTV
I have a LG 42 inch plasma tv model 42pc3d....the other nite my wife was watching tv then she heard a loud pop and then noticed that the tv has sound but the picture is washed out mainly with black and...
Hello Tiangston9.
These plasma TVs have a common failure with the Ysus boards, more specific an IC that is underneath the big heatsink. The capacitors in the power supply became defective as well.
Check the link to find parts to fix your TV.
Mar 09, 2017 | LG 42PC3D 42 in. Plasma Television
Jan 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
Jan 15, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Pioneer PDP-425CMX 42" Plasma Tv
Try the scan PCBs that run down the side and the connectors that hook them up to the rest of the system. That would be my first place to start.
Unfortunately I don't have service manuals for non-european models. What is the date of manufacture?
Nov 16, 2007 | Pioneer PDP-425CMX 42 in. Plasma...
Samsung PN42A450 Plasma TV Logo
50 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
