I need a license number for the Arcsoft totalmedia 3.5 which is insatalled oon a windows 7 home premium 2011 programme. Can you help pleas
SOURCE: ArcSoft TotalMedia Theatre 3 issue
Download from Arcsoft the "BD Assistant"and it will tell you where your system is failing the HDCP check.
I had an issue with the LogMeIn mirror driver showing up as my graphics card. When I uninstalled it, my HDCP status was good again. The funny thing is LogMeIn and TMT3 run fine together but only under certain circumstances changing multiple monitors do you get this conflict.
SOURCE: i have totalmedia 3,5 arcsoft
The router may not be the problem. It may be the compatibility issue. Most programs written for Windows Vista also work in this version of Windows, but some older programs might run poorly or
not at all. If a program written for an earlier version of Windows doesn't run correctly, you can try changing
the compatibility settings for the program, either manually or by using the
Program Compatibility troubleshooter. Go to the Windows website to watch the video. (1:26) If changing the settings doesn't fix the problem, go to the
program manufacturer's website to see if there is an update for the program. Do not use the Program Compatibility troubleshooter on older
antivirus programs, disk utilities, or other system programs because it might
cause data loss or create a security risk. Follow the instructions in the troubleshooter. If you cannot install a program, insert the installation disc for
the program and, using the troubleshooter, browse to the program's setup file,
usually called Setup.exe, Install.exe, or something similar. The troubleshooter
is not designed to work on programs that have an .msi file
name extension. You can also open the Program Compatibility troubleshooter by
right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility. To change compatibility settings manually for a program,
right-click the program icon, click Properties, and then
click the Compatibility tab. Setting Description Compatibility mode Runs the program using settings from a previous version of Windows. Try this setting if you know the program is
designed for (or worked in) a specific previous version of Windows. Run in 256 colors Uses a limited set of colors in the program. Some older programs
are designed to use fewer colors. Run in 640 × 480 screen
resolution Runs the program in a smaller-sized window. Try this setting if
the graphical user interface appears jagged or is rendered
improperly. Disable visual themes
Disables themes
on the program. Try this setting if you notice problems with the menus or
buttons on the title bar of the program. Disable desktop composition
Turns off transparency and other advanced display features. Choose
this setting if window movement appears erratic or you notice other display
problems. Disable display scaling on high DPI
settings Turns off automatic resizing of programs if large-scale font size
is in use. Try this setting if large-scale fonts are interfering with the
appearance of the program. For more information, see Make the text
on your screen larger or smaller. Privilege level Runs the program as an administrator. Some programs require
administrator privileges to run properly. If you are not currently logged on as
an administrator, this option is not available. Change settings for all
users Lets you choose settings that will apply to all users on this
computer. Article ID: MSW700015
Here is the article that addresses running older program with Windows 7
Make older programs run in this version of Windows
Warning
To run the Program Compatibility troubleshooter
Tip
SOURCE: cannot remove arcsoft totalmedia from
Try to boot/run your PC to safemode for to uninstall the software.
