Question about Frigidaire Ovens
My frigidaire electric wall oven feb27s5asb dies noto beat above 320
Posted by pollici on
  • WT Door
    WT Door Dec 22, 2016
    Hi pollici, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? or tell us how you fixed it.
WT Door
    Habit-Forming:
    New Friend:
  • 70 Answers
IF you have checked that the Temp sensor reads 1080-1100 ohms at room temp and your broil and bake element are 17-35 ohms, then it is the electronic oven control. please turn off power before troubleshooting.
Posted on Dec 22, 2016
5 Related Answers
Anonymous
SOURCE: Frigidaire Wall Oven does not open once hot
Well at least I seem to have solved it. I kept hitting clear off and tugged on the door and it finally opened. Once opened I noticed there is a metal hook at the top of the opening to the oven. Mine was rotated to the 9 o'clock position. I took a pair of pliers and rotated it until the open part of the hook was in the 12 o'clock position and tugged outward on it just a bit and the "door locked" signal went off. I hit clear off again and the beeping has not resumed. I'm thinking the hook got partially stuck in the wrong position after it automatically locked the door for cleaning.
Waiting for the oven to completely cool off before I close the door again.
Hope this helps someone else out there!
Posted on Jan 08, 2009
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
Posted on Apr 26, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: oven not heating
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Posted on Jun 23, 2009
tbirdfan1
Michael Thomas
  • 3053 Answers
SOURCE: What does the F 5 error message displayed on
Hello there:
Here is what the code means and what needs to be dne to resolve this problem
F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control)0dd70e1.jpgShould be something like this
Posted on Jun 06, 2010
shadow_ri775
Rob Cabs
  • 274 Answers
SOURCE: How to get manual for the Frigidaire electric wall oven 27 inches?
You have several questions on here with diferent models, i suggest you go to the frigidaire website under owner support and register your model for a manual download. http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/undefined
Posted on Jan 20, 2015
Jan 20, 2015 | Frigidaire 27 Inch Stainless Steel Wall...
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
INSTRUCTION MANUAL FOR LEEB30T9FEA
Hello Brent Delong - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
Mar 08, 2013 | Frigidaire 27 in. Electric Double...
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
I need the instruction manual for a frigidaire gallery oven
Here is a link to a website that says the manual is for a wall oven - http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205312en.pdf
Here is the link to Frigidaire manuals as well and maybe you can find the manual there if the first link is incorrect -
Aug 08, 2011 | Frigidaire 30 in. Electric Gallery Series...
I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
Nov 28, 2010 | Frigidaire 30" Built-In Double Electric...
What does the F 5 error message displayed on Frigidaire - 24" Built-in Single Electric Wall Oven FEB 5 56cbs mean?
Hello there:
Jun 05, 2010 | Frigidaire 24" Built-in Single Electric...
What would be causing my frigidaire wall oven
sounds like you have problems with the main pcb,or clock.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 10, 2010 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
98 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
