Question about Shop Vac Vacuums
My very old 6 us gallon wet-dry shop vac now blows instead of sucks.
When I turn it on instead of proving suction it blows.
Posted by Jack Baldwin on
bcas6924
    Habit-Forming:
  • 144 Answers
Connect the hose on the other end where it say vacuum not blow.
Posted on Sep 19, 2016
  • Garry Henderson
    Garry Henderson Dec 15, 2020
    it is hooked to vacuum port but,blows through blow port
Garry Henderson
It is hooked to vacuum port but blows out the other port
Posted on Dec 15, 2020
We have a dirt devil that when the canister is engaged, it no longer has suction. The canister is empty. Thoughts?
you turned the switch to blow instead of suction
remember them days .. no .. i do
Jan 12, 2015 | Hoover Vacuums
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
Hello,i have a vacuum cleaner but their is no air pressure in it
Do you mean the suction is very low? Or really none at all?
If low, there can be a hair/dust ball clogging the tube way deep. If you can remove it and the vacuum cleaner has an 'blow air' out you could connect the tube and blow the junk out possibly. The clog could be inside the unit instead.
If no suction at all then it's probably a complete disconnected tube somewhere.
Oct 06, 2013 | Oreck UPR014T XL Pro 14 Upright Vaccum...
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
Aug 17, 2011 | Electrolux Guardian Bagged Canister Vacuum
Suction stopped working immediately
There is a hose on the unit. Disconnect it at both ends. Stretch it out. Look down it. If you can't see down it, rod it out.
May 28, 2009 | GE Vacuums
No suction - air blowing OUT from tube
Is the air blowing out of the pick-up tube or out of the exhaust tube on the unit? I am assuming the pick-up tube. The installer has hooked your system up to the exhaust tube on the unit. Hook up to the intake on the unit instead.
May 27, 2009 | Hoover L2310 GUV Central System Vacuum
Cleaning a drain using kirby
first can it pick up water if so you put take the hose on suction and wrapp a rag around the end so you get full suction in the drain and turn it on.if not hook the hose up so it blows instead of sucks,do the same thing with a rag around the end of the hose and seal the hose in the drain,then turn it on.if you have a shop vac that will work better
Apr 27, 2009 | Kirby G6 Bagged Upright Vacuum
Stop vacuum from blowing to suction
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559995
Generic problem for all Vacuums
Posted by keyerica74 on Apr 30, 2008
Stop vacuum from blowing to suction…..
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You’re vacuum is blowing because your (round vacuum) belt is on backwards and is blowing instead of having suction – please reverse the belt and most vacuums have a diagram on the bottom of the vacuum to tell you which way to install. Not knowing the brand name or model #, if you have Questions, Contact you local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Reverse Suction
You have a clog either at the inlet by the brush roll or in the hose. Pull the hose and check for suction at the end of the hose, If it is ok there, then you have a clog from where the hose hooked into and the inlet at the bottom. If at the end of the hose there is no suction, take the hose off and see if you see a clog in it. If no clog there, then check all filters, if they get clogged, then air can't flow thru them and no suction.
Dec 31, 2007 | Hoover U5507900 Elite Rewind Bagless...
Vacuums Logo
234 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Bill Johnson
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
