2004 GMC Envoy Logo
E
Edward Goss Posted on Sep 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 envoy won't start after my house got struck by lightening. Coincidence?
Car was in driveway. major tree behind house, about 100 yards away was struck by lightening. Car is dead, tried charging and jump starting, nothing. No sound, no gauges. Can something be damaged?
Marvin
Level 3:
Top Expert:
  • GMC Master 85,242 Answers
  • Posted on Sep 18, 2016
Marvin
GMC Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024077
Points
266281
Yes the lighting likely burned out the car's electronic control module(s). Contact your insurance company, this can be a very expensive repair.
Testimonial: "Thank you. I called the insurance company and they'll be out tomorrow. I sure hope the vehicle will survive. Just put $2,000 into it last month. I planned on keeping it a lot longer."
  • Marvin
    Marvin Sep 20, 2016
    If they try to total the truck show them the repairs you had done you will get more on the settlement
  • Edward Goss
    Edward Goss Sep 20, 2016
    Thanks. I'll do that
2004 envoy clicks once under the hood but won't turn over
Ckeck your cranck shaft sensor and if all fuses are good and see if you have fuel too
In park but still rolls
disconnect the shift cable and move shifter to park pull cable hard andreattach also check the switch behind the brake pedal
6helpful
IM TRYING TO REPLACE THE THERMOSTAT ON MY 2004 ENVOY WHERE IS IT LOCATAED EXACTLY
The thermostat on this vehicle's In-line 6 cylinder engine is on the driver's side of the engine, below & behind the alternator. You have to remove the alternator to gain access to the thermostat housing. You also need to disconnect the battery before you remove the alternator to avoid sparks and shorts.
Most directions outline removal of the alternator to gain easy access to the hose clamps, bolts and housing of the thermostat. I have located a site that after free registration, has detailed instructions on how to do this job, and the link below that describes an easier method with photos. Check out:
http://forums.trailvoy.com/showthread.php?t=54225&highlight=replace+thermostat
Please tell me where locate the theromostat in
The thermostat is located inside the thermostat housing. To find it follow the upper radiator hose to the engine block.
Depending what size of engine you have the location is different.
The thermostat on this vehicle's (the Envoy & Trailblazer are essentially the same vehicle) In-line 6 cylinder engine is on the driver's side of the engine, below & behind the alternator.
If you have a V8 cylinder engine is in front of engine see the picture. Item 303 thermostat housing, 305 thermostat, and 304 thermostat gasket.
Today at my sisters house lightning struck her sprinkler system and now my car wont start. And my car was parked in her driveway. Her husbands car is not starting also.. My light work it just wont start......
The security system (VATS/PassKey) is faulty.
There is an easy DIY way of bypassing the VATS system entirely, including the TDM (that goes faulty very often with the age of the car). You can find the write-up here:http://newrockies.ca
6helpful
What is the best type of motor oil for 2004 GMC
this engine calls for any major brand 5W20W (I prefer Valvoline), in very hot climates u can use 10W30W, but no heavier.
1helpful
Radio works ok. Cassette ejects tape, won't play. Cd skips/hesitates but plays. Panasonic 6 disc changer(factory installed) will not recognize cds. It gets err 1 msg. Would replacing the battery cause...
No, replacing the battery is not your problem. Must be pure coincidence..
Tape is ejecting because the deck is faulty. Either a broken belt or a broken plastic gear assembly. CD players in this model were made by SONY and are troublesome. Rather than trying to get someone to fix it, go to your local salvage yard and see what they have. They are for sale on ebay also. They are basically "throw-away" units as SONY struck a deal with GM and GM can't supply replacement parts. PLUS... there aren't too mnay shops around that fix these units.
2001 chevy silverado 1500 headlights wont shut off
You will have to have the dealer reset the security light to restart vehicle.Check all engine and chassie grounds because this is where the lighting would exit the vehicle.It sounds like a ground burnt through.
46helpful
2answers
Replace thermostat on 2004 gmc envoy
The thermostat on this vehicle's (the Envoy & Trailblazer are essentially the same vehicle) In-line 6 cylinder engine is on the driver's side of the engine, below & behind the alternator. It is not found in the typical location (which may be for the 8 cylinder engine), in an answer above.
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
