Question about Hitachi 42 in. Diagonal Class Full HD1080 Plasma TV with 3 HDMI
The volume on my Hitachi HD1080 tv quit working. How do I get it working again
Posted by david smith on
Dean Kelley
    Habit-Forming:
    New Friend:
  • 39 Answers
Found this link for you. May not be your issue, but good luck.
https://www.avforums.com/threads/hitachi-l19d01uwk-volume-control-problems.1193173/
Posted on Sep 22, 2016
How do get the tv to work with my dvd player
You should be able to just connect the set via an HDMI cable to your DVD player for it to play. You then will have to select using the TV remote the HDMI connection the DVD is connected to.
I do not believe the TV will switch to the DVD player automatically when connected via HDMI. My TV doesn't, though it's not the same as yours.
Sep 26, 2015 | Hitachi P50V701 50-Inch Full HD1080 Plasma...
The volume quit working
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 24, 2014 | Hitachi Gst Hitachi LE55X04A 55 inch Multi...
Volume not working on Hitachi L42s503 TV
Is the sound ok and you are not able to control the volume from the remote?
Aug 04, 2012 | Hitachi L42S503 TV
Where does the HDMI cable plug into Hitachi HD1080 TV other than front?
Here is a Picture Diagram for you, This shows where your HDMI etc are all located.
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/ubcg/plasma_tvs/P50H401.pdf
Hope this Helps you out.
If this Does then please Leave a Thumbs up
Cheers
Little Dish Fitter
Oct 03, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Remote will not change the volume
Is the front funtion button works in the TV the it could be a bad remote controller(the button switch inside) :)
Apr 14, 2009 | Hitachi 43FDX01B TV
Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Dec 26, 2008 | Hitachi 26HDL52 26 in. LCD Television
Code for my tv
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0145
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 11, 2008 | iLO 2600 Television
Buzzing/humming sound from rear of TV unaffected by volume settin
Hi.
I think you have problem with the main digital PWB
You need change that part.
Nov 18, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Open Questions:
See all Hitachi 42 in. Diagonal Class Full HD1080 Plasma Questions
Hitachi 42 in. Diagonal Class Full HD1080 Plasma TV with 3 HDMI Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
