NEED TO CONNECT TRAILOR WIRING HARNESS TO CARS LIGHTING SYSTEM (SIGNALS,HEADLIGHTS,BRAKES.)
SOURCE: 2007 Hyundai Santa Fe - Replacing fog light
hi have not had pleasure of this on santa fe yet? but will try to help dependant of which side o/s or n/s ? i would first remove the screws holding the front of the under engine plastic cover/shield and drop down sufficient to gain view/access? to the rear of fog lamp then if a cover is on? try turning anti clock to remove? or if rubber cover pull off? then the bulb and clip should be visible? unplug the wire from bulb then the spring clip holding bulb in place normally just sring the 2x top ends together and swing down/clear to remove bulb? refit new bulb correctly! pay attention to position old bulb positioned? then clip securely and re connect wire at this stage it would be best to ensure bulb works ?? before you re assemble all else? wish you luck and hope this helps with your problem ?
SOURCE: Access to tail light wiring harness plug
You have to remove the access panel on the interior side of the passenger compartment to access that connector.. it's a simple procedure after you see the wire harness and bulkhead boot.
SOURCE: spark plugs and wires on 2003 santa fe
why would you fix a problem that is not there.if it is fine then enjoy it.plugleads only get changed if faulty.
SOURCE: I need to know the wire colors to the hyundai
RADIO 12V - red +
RADIO GROUND - black -
RADIO SWITCH - yellow +
RADIO ILLUMINATE - green/orange +
LF SPEAKER + white - brown
RF SPEAKER + yellow - black
LR SPEAKER + red - blue
RR SPEAKER + green - orange
