Question about 2008 Toyota Yaris - Hatchback, 3-door - Base Rack System
How to remove the inner end of a tie rod end - 2008 Toyota Yaris - Hatchback, 3-door - Base Rack System
Posted by Daniel Chanda on
Marvin
    Top Expert:
  • Thule Master
  • 85,239 Answers
It unscrews.
Posted on Sep 18, 2016
Inner tie rod removal with tool
One end of the tie rod is a left hand thread
make sure that you are turning it the right way
Apr 12, 2015 | 2005 Hyundai Tucson GLS
Have anyone out there ever change inner tie rods on a1995 honda odyssey?,if so simply explain,THANKS
Procedure on replacing the inner tie rod ends:
1) Raise and safely support the vehicle.
2) Remove the front wheel/tire assembly.
3) Clean the steering rod between the steering boot and outer tie rod end lock nut with a suitable penetrating lubricant and a clean cloth or shop towel.
4) Loosen the outer tie rod end locking nut 1/8 turn.
5) Loosen the steering boot clamp(s), and slide the small clamp off the boot.
6) Carefully loosen the boot and slide outward off the steering rack and onto the shaft to expose the inner steering rod mounting fastener.
7) If necessary, position the inner steering rack shaft in or out to allow for additional access.
8) Relieve the steering rod nut locking tab from the inner steering rack shaft, then loosen the steering rod ball socket nut 1 turn.
9) Matchmark the tie rod end to the threaded shaft.
10) Remove the cotter key and castle nut from the outer tie rod end threaded spindle, and using a tie rod end removal tool, remove the tie rod from the steering knuckle.
11) Hold the tie rod with a wrench, and remove the outer tie rod end from the threaded rod, counting the number of complete turns it takes to remove the tie rod end from the shaft. Write the number of turns on a piece of note paper.
12) Remove the tie rod end lock nut from the threaded steering shaft.
13) Slide the steering rack boot off the shaft.
14) Remove the inner steering rod ball socket nut from the inner steering rack shaft.
To install:
1) Inspect the tie rod end for looseness, and the steering rack boot and tie rod end boot for cracks deterioration or damage and replace as necessary.
2) Clean steering rack shaft and apply a light coating of Genuine Honda Power steering fluid as necessary.
3) Apply a medium strength locking agent to the threads where the inner steering rod ball socket mounts. Use a new locking washer and a new stop washer, and install the inner tie rod onto the steering rack shaft.
4) Tighten the inner tie rod end fastener by 58 ft. lbs. (78 Nm)
5) Peen the lock washer over the nut or onto the flat surface of the steering rack shaft.
6) Apply silicone grease to the outer circumference of the inner tie rod end ball socket, and onto the groove just outside of the socket.
7) Apply silicone grease to the inside of the small end of the steering rack boot, and slide the boot over the steering shaft and onto the rack and install the boot clamps. If the boot has air hose fittings make sure they are installed as removed.
8) Apply a light film of an anti-seize compound onto the threaded tie rod end, and install the tie rod end lock nut.
9) Install the tie rod end onto the tie rod, turning it in exactly the number of turns it took to remove it.
10) Install the tie rod end following the tie rod end installation procedure.
11) The balance of installation is the reverse of the removal procedure.
12) Check the front end alignment and adjust as necessary.
Sep 10, 2012 | 1995 Honda Odyssey
I need to rplace the inner tie rods.
Inner tie rods rarely if ever need to be replaced in my experience: outer tie rod ends are far more common. Its not impossible so here's how.
1. remove the tie rod ends from the knuckle.
2. remove the clamp for the rubber bellows on the rack ends, and slide the bellows down the rod.
3. Turn the rack to fullleft or right as needed to get access to the inner rod end that screws into the rack.
4. There's a lock tab that has to be bent flat. This locks the rod end into the rack.
5. You'll need a (probably) 32mm wrench to undo the rod end from the rack.
6. Note how the lock tab is fitted to the rack/rod end.
7. Put in the new tie rods.
If your garage mechanic told you the inner tie rods are worn out, I'd ask why they think so. At step 4. above, try rotating the rod. This should be quite difficult. There should be NO evidence of slop or wear in the inner joint. What more commonly wears is the bushes on the end of the rack. These bushes are easily replacable with the rack in the car.The tie rods have to be removed to do this. So, when the rods are off, inspect the rack bushes for wear.
SD
Jun 25, 2011 | 2003 Mitsubishi Outlander
The first step in replacing the inner tie rod is to remove the tie rod end. It's basically a three step process, where you start by loosening the jam nut that's used to set the alignment (toe-in or toe-out). That jam nut determines how far up the inner tie rod the tie rod end is fixed. The tie rod end is hollow and threaded, so it can be screwed on or off the inner tie rod. Any procedure for removing a tie rod will start by telling you to count the turns you unscrew the tie rod end, something that I didn't do, and I'll save the explanation for the end:-) After you loosen the jam nut, you remove the cotter pin from the post on the outer tie rod ball joint, and unscrew the nut that holds the ball joint into the tapered fitting on the steering knuckle (video to right). After you pop the outer tie end free of the steering knuckle, you can unscrew the tie rod end. from the inner tie rod, but you need to grip it with something. Inner tie rods normally have some flat surfaces or a splined surface for grabbing with pliers. In this case, I needed two pairs of visegrips and a clamp to hold the visegrips on the inner tie rod from moving in order to get the outer tie rod end broken free and turning easy. That video is below. I happen to own the shop manuals for my Dodge Omni, so I was able to study the procedure for replacing the inner tie rod in detail. I didn't follow it for a couple reason. First, they show my type of power steering rack (Saginaw vs TRW) needs to be removed from the car to change the inner tie rod. That's a lot of extra work, not to mention the fact I buried one of the crossmember bolts in my unibody and flooring repair! So I went with an inner tie rod removal kit from Harbor Freight, manufactured by U.S. General (in Taiwan). The tool is very simple, basically a large steel tub with a snap in opening for a large crows foot insert on one end and a 1/2" socket drive on the other end. The kit is shown in the photo to the lower left (which I need to replace), and a video of the procedure is shown below. The kit wasn't quite right for my car, I had to use an oversized crows foot and the ball joint housing on the inner tie rod was too long, so the flats on the housing were barely held with the crows foot positioned by hand at the very end of the tool. But I got it out.
Dec 16, 2010 | 1992 Buick LeSabre
How do i loosen the outer tie rod end to remove it from the bushing once tie rod is out of streeing knuckle i know it will need to be aligined and i need to count treads when putting new outer tie rod end...
You may need a propane torch to heat up the nut on end of outer tie rod. With tie rod still attached to steering knuckle try to loosen the outer tie rod end nut that is connected to inner tie rod. Pull tie rod end back out of knuckle. Use pliers or vise grips to hold inner tie rod end while turning outer tie rod end to the left.
Oct 27, 2010 | Dodge Intrepid Cars & Trucks
How difficult to replace inner tie rod end on 06 silverado 2wd?
Not that hard, just spray the tie rod sleeve with WD40 night before and let it soak in. Remove the collier pin and and nut and hammer the old inner tie rod end out of the Track rod with a 5 pound sledge hammer. Remove the inner tie rod end from the sleeve and don't forget to mark the distance so you can place the new tie rod end at the same length. Reinstall the inner tie rod end to the Track rod and tighten the nut and replace the collier pin with a new one. Grease the fitting and go for a test drive, if the truck does not wonder then your good to go with out a alignment. Good luck and hope this helps, Note, make sure you have to right inner tie rod ends. Each side has different thread rotations.
Jun 03, 2009 | 2006 Chevrolet Silverado 1500 2WD
Rack pinions and bushing installement
pretty decent job ahead first jack up car support with jack stands remove front wheels remove nuts on tie rod ends remove tie rod ends from spindles with tie rod end tool or tap with malet were they sit to loosen them hit the spindle area not the tie rod or tie rod threads then dissconnect power steering lines from steering rack also disconect steering linkage to rack there should be 2 main bolts holding assembly to frame remove them should free rack i know that car may have a unique design were u may have to remove inner tie rod ends first if it has those round bushings that always go bad disconect inner tie rod ends behind engine on top of steering rack then remove rack from wheel well replace those inner tie rod bushings u may be able to leave outer tie rod end connected to spindles and u may be able to get to the sterring rack from behind engine good luck
Mar 28, 2009 | 1997 Chrysler Concorde
1996 chrysler concorde, how to take off the inner tie rod?
I used this website: http://www.allpar.com/fix/intrepid-steering.html It worked perfectly. To add to it, I used a tie rod puller tool rented from Oreilly Auto Parts for only a few bucks, to press the old bushing out of the inner-tie-rod end. Worked very well. Easier than removing the entire tie rod, and hammering it out. However, removing the entire tie rod would make re-assembly easier. If I did it again, I would strongly consider removing the driver side tie rod from the car, then attaching the inner tie rod end 1st. Meaning, attach the passenger side inner tie rod 1st, then the driver side inner tie rod with new bushing, then re-attach the drivers side outer tie rod. That would probably be the easiest way on this 1996 dodge concorde, due to the fuel line that's in the way....
Mar 17, 2009 | 1996 Chrysler Concorde
I need to replace the inner tie rods on my 97' conti......need a diagram of how to and any other info pertinent to the job - Bair
If this is a rack and pinion type steering, in order to remove the inner tie rods you will first have loosen the jam nut at the outer tie rod end,next unbolt the outer tie rod from the steering knuckle, unscrew the outer tie rod end off (be sure to count how many turns to remove), next remove the inner bellows boot (black boot) from the tie rod / rack and pinion, next is to unscrew the inner tie rod from the rack assembly (the do make a tool for this to make it easier) but if you do not have the tool,you can sometimes use a big pair of channel locks or a big enough wrench to fit on the fitting on the inside of the inner tie rod, and just unscrew the inner tie rod (normal left=loosen, right=tighten). Hope this helps. Would also recommend having it aligned after you are finished.
Mar 12, 2009 | 1997 Lincoln Continental
Tie rod problem 98 Dodge
There is a tool that you can use that will make it easier for you. To get to the tie rod end, remove the wheel and take the outer tie rod end loose from the hub. You will have to use a hammer and hit the socket where the end goes into the hub to free it up. Once you have the tie rod loose from the hub, loosen the nut behind the outer tie rod end. Count the revolutions as you unscrew the outer end off and write te number down so you will know how far to put it back on. This will save your alignment. Now, the end that is still there is your inner tie rod end. You will have to undo the bellows boot to get to the nut. The tool will slide over the end and secure onto the nut. Now you just unscrew this and replace with you new inner tie rod end.
Please remember to rate this fix.
Feb 16, 2009 | 1998 Dodge Grand Caravan
2008 Toyota Yaris - Hatchback, 3-door - Base Rack System Logo
102 people viewed this question
Top Thule Vehicle Parts & Accessories Experts
randymanfive
Marvin
Marvin
Serge Joncas
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
