Model AR6F105 When the cycle starts it work for few minutes and switching off automatically checked the power supply
SOURCE: Bosch WFB2005 triping mains
Couple of other questions and some ideas.
Do you know what sort of breaker is getting taken out? Is it Earth Leakage, or Overcurrent? Earth leakage with a delayed onset would be really odd - while overcurrent breakers often have a slow-acting thermal element to protect against small ooverloads. In this case. it's not that the fault develops after a delay, it's just that the breaker leaves it a while before tripping.
A small overload when the machine is nominally off is quite a hazardous situation - it means that something somewhere in the system is likely to be getting very hot, and being allowed to get on with it for several minutes. This is a good way for house fires to start. The best way to test for this is to put a clamp meter (these are relatively cheap) round the live conductor (only) in the power lead, and see if you're drawing excess current at the end of the cycle. If you are, then it's just a matter of progressively disconnecting components within the machine until you find the culprit.
Ifyou're tripping an earth leakage breaker, then Dazmaraz's insulation tester is the only real way to go. Once again, get the problem to show on the tester, then progressively disconnect components until the problem disappears. Experience suggests that a proper insulation tester is much more likely to be successful than a multimeter (multimeters don't work at a high enough voltage to excite a lot of insulation breakdown type faults).
A.
SOURCE: washing machine
the problem you are have there is if the machine is bolwing a fuse becauce the heater element is falty replace the heater and all shall be fine again noffie....
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
SOURCE: Miele W698 Hydromatic washing machine serial no,10/11236327 (purchased 1992)
SREALNO AND MODELS PROBLEM
SOURCE: simpson enduro 701 washing machine
you have a faulty brake motor. It pulls in and releases the brake. When pulled right it it contacts a switch which lets the other actions like washing and spinning to occur. $77 to $86 off ebay or appliance stores. turn off ac. remove back off machine. reach around left side of frame at the bottom of the tub and push the brake forward manually and let the little plastic retainer turn sideways and release the wire rope retainer that comes out of the brake motor. remove the power cable to the brake motor by pulling out the connector on the right side under the tub. remove the two 8mm screws retaining the brake motor and remove the brake motor. reverse procedure with new item.
enjoy uninterrupted washes!
