Question about Acer Extensa Computers & Internet
Error message and I have no cd rom
Error message Windows could not start because the following file is missing or corrupt I have no cd rom
Posted by Tanya Louise on
5 Related Answers
Adnan Manzoor
  • 102 Answers
SOURCE: missing or corrupt windows\system32\config\system file in XP
sciberteach:
Go in the BIOS, in the boot sequence make your DVD player as the 1st number device to boot from, restart your machine and do follow the article (you should know the admin password to go into the system drive):
http://support.microsoft.com/kb/307545
Note: If you are too overwhelmed then your Product recovery DVD will give you your original OS and all settings back.
Posted on Dec 10, 2007
LaptopExpert
Garry Romaneo
  • 458 Answers
SOURCE: Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Posted on Jun 12, 2008
Anonymous
  • 104 Answers
SOURCE: \Windows\System32\Config\System; Repair w/CD-ROM; NO CD-ROM
if you can get an external cd/dvd drive from a friend, then you could solve the problem.
other solutions would mean that you will reinstall windows again. This takes more time and has a few tricks to be done from a flash drive.
Posted on Mar 24, 2009
Anonymous
  • 40 Answers
SOURCE: get an error message that windows would not start missin or corrupt windows\system32\config\system
you can use system restore to solve this problem .
try to restore your system to an earlier working restore point.
this will fix your problem.
Posted on Apr 22, 2009
Anonymous
SOURCE: I have a asus eeepc 900 netbook.suddenly it stop
Windows could not start because the following file is missing or corrupt:
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
Posted on Jun 22, 2010
Windows\systems32\config\system file is missing or corrupt
You can order a new set of disks from the manufacturer or pull out the had drive and plug it into another PC or buy an external hard drive dock . Newegg has them for around $20
Mar 09, 2014 | Insignia Computers & Internet
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
Jun 15, 2010 | ASUS m6n Notebook
Windows setup using the original CD-ROM
you have to re install the copy of the file missing, if you do not re install this file. you wont be able to install windows. you need to re install this file to avoid this messages, you a have a windows installation disc have a copy install to your pc
Nov 25, 2009 | Toshiba Satellite Pro L300 Notebook
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
I can't start my windows there is a error message
Well you need you windows XP CD to fix this problem. You have to boot to your Windows XP CD and repair the operating system. Any windows XP CD can be used to repair your computer. If there's none. Call the manufacturer of the computer and see if they can send you one.
Feb 10, 2009 | Microsoft Windows XP Professional
Windows XP Home Edition Crashed After Loading Service Pack 2
hey coco
nothing happens when you try to use the recovery console right by pressing "r".
try this again and again , sometimes it idles but its still running, if the error appears, restat again.
some corruptions maybe beyond our control and sometimes the only solution for this is to recover the inportant files you have on that HD and do a reformat...
Jan 24, 2009 | Microsoft Windows XP Home Edition
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Computers & Internet Logo
56 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
