Question about Epson WorkForce WF-7620 Wireless Color All-in-One Inkjet Printer
How do I print on 11 x 14 paper? According to the online manual, the Epson WF - 7620 does print 11 x 14. And that is why I bought the printer, but I cannot figure it out!
Posted by Bhava on
Ravi
  • Epson Master
  • 1,682 Answers
Load A3 size paper on the lower tray.
Verify you see A3 as an option in paper setuo on the printer screen against tray 2.
Make sure you have selected A3 on the software before you print.
EPSON WORKFORCE A3 WF 7620DTWF
Posted on Sep 18, 2016
Testimonial: "Sorry I have not responded sooner, but I didn't bookmark this page and couldn't find it until now. I tried to cheat, and not insert an A3 size paper. I have an 11 x 14, but that did not work. So now I have to go out and find a ream of paper that is an A3 size, and waste more time and money. So far I have spent over $250 for the printer, and have had to replace 3 ink cartridges for another $150. And in order to print in black, I have to buy another ink cartridge for the third color that just ran out [These were the sample inks that came with the machine.] So now I will be into it (with travelling expense etc.) at about $600! And, it doesn't even print the size paper that I bought it for (which it clearly states in the manual it prints) without having to mess around like this. Very disappointing. If I could take it back I would, but I am passed my 30 day trial."
  • 6 more comments
  • Ravi Sep 22, 2016
    You can print 11x14 (also called a legal size) from the manual feed tray or also reffered as Multi Function (MF) in either color or BW.
    You do not need A3 size oaoer for it.
    You cannot use the A4 or A3 marked trays.
    The multi-function tray should hold fewer papers like 15~20 unlike the other trays that hold 250
    Not sure if Epson insists to have all cartridges while you consume only black.
  • Bhava
    Bhava Sep 22, 2016
    OK, I tried that, but an error message comes up saying, "the paper source setting is invalid. Touch detail to check the available settings".
    When I click on "details" it does not list "legal" (or 11x14) size paper as being supported.
  • Ravi Sep 22, 2016
    My apologies.
    Legal size is 8.5x14 inches
    A3 is 11x17 inches
    your expectation is 11x14 which is Non-standard.
    hence you will have to use A3 and cut the rest
  • Ravi Sep 22, 2016
    See page 67 of the manual athttps://static.bhphotovideo.com/lit_file...
    It also states 'user-defined' Try this as well.
  • Bhava
    Bhava Sep 22, 2016
    My predicament is that I am printing reproductions of my art, which is produced on 11 x 14 paper. In the beginning , I did use 11 x 17 and trim it down. But the paper was too thin for my needs. So now I am using 11 x 14 art stock paper, which is a little thicker than the regular paper (office paper). I set the size to 11 x 14 in the "user defined" option, but when I try to print it, an error message comes up preventing the printing. Why does it say in the manual, even the one you provided, that you can print on 11 x 14 paper, if you can't? Something is missing, and I need to find out how to do this. I just called the store that I bought the printer from, but because I no longer have the box (even though it is not past the return date), they said they cannot excepted back.
  • Ravi Sep 22, 2016
    which country and city are you in ? Is there an Epson office there ?
  • Ravi Sep 22, 2016
    Try this.https://www.epson.com/cgi-bin/Store/supp...
  • Bhava
    Bhava Sep 23, 2016
    No, there are no Epson offices here. I am using an iPad, and that option is not available, but I have laptop and it does. I guess I'll try it there. Thank you for all the help! If you don' mind, I'll be back for more of your guidance.
Epson printer WF 7620 0x69 error
The most effective method to FIX Epson Printer Error Code 0x69 It is safe to say that you can't fix Epson Printer Error Code 0x69? Try not to sit around time any further. View this article which contains ae stepwise procedure to fix the Epson Printer Error Code 0X69. In the event that you carefully follow this total guide on the best way to fix Epson Printer Error Code 0X69, you will effortlessly have the option to determine the Epson Printer Error 0X69.
Follow any of the methods beneath to fix the Epson Printer Error Code 0x69.
Stage 1: The Epson Error Code 0X69 can likewise happen because of the circuit issue which is identified with your printer ink framework or with the print motor. Along these lines, to determine this follow the underneath steps.
Turn ON the Printer and turn it OFF soon after it begins boosting.
Presently hang tight for 15 Minutes and turn ON your printer once more.
Check if the Epson Error 0X69 is fixed or not. On the off chance that the error isn't the settled, at that point the issue must be with equipment, which can be unraveled through Step 2.
Stage 2: When you are utilizing a more established variant of the Windows OS, the Epson Printer Error 0X69 happens. In this way, you need to refresh your Microsoft Windows OS to determine this issue. You should have in any event Windows 7 OS to work Epson Printers.
As a matter of first importance, switch ON your PC.
Snap on the Start choice and type Windows Update in the hunt box and snap on the Enter button in your console.
Presently, tap on the Windows Update choice to start the refreshing procedure.
At the point when the Windows is effectively refreshed, restart your PC and sign in as the executive.
Presently, tap on the Start choice and snap on All Programs and afterward go to Accessories.
In Accessories, go to System devices and afterward click on the System Restore alternative.
A discourse box will show up on your screen where you need to choose the 'Reestablish my PC for a prior time' alternative and tap on Next.
Presently select the most recent framework reestablish segment so as to finish the procedure.
Presently tap on the 'Following about the affirmation window' alternative for completing the procedure.
Restart your PC and print an example record utilizing your Epson Printer to check if the error is fixed or not.
Customer care bunch has readied and all around qualified specialists for examining the email secret word recovery issues. If customers need assistance these pros furthermore help them in an aware way.
Mar 30, 2018 | Epson Office Equipment & Supplies
Why won't my Epson WF-7620 print on thick paper when fed from the rear slot
Are you setting the printer to A3 when you hit print? When you select print you will get a on screen box where you can change options and then confirm by clicking print. Most printers are set to default legal size.
Aug 07, 2016 | Epson WorkForce WF-7620 Wireless Color...
How do i fix epson printer OxF4
That usually comes from paper jams. Make sure all paper is unjammed and turn off power for a couple minutes. Clear any faults and continue. Make sure your drivers are up to date too.
Jun 13, 2016 | Epson WorkForce WF-7620 Wireless Color...
Epson WF-7620 will not print black.
I had a similar problem on my 3640 and had to run the clean cycle about 20 or so times. If you feel you are capable, you can also remove the print head and do a manual clean. YouTube has a few videos on how to do it. I have done this to one of my printers with very good success.
Apr 26, 2016 | Epson WorkForce WF-7620 Wireless Color...
Reset Epson WF-7610
I've seen a program reset function which is downloadable from the internet. You will have to google it. I think it's only available on a windows operating system.
Sep 07, 2014 | Epson WorkForce WF-7620 Wireless Color...
Why is my WF 7620 using excessive black ink?
Check the print settings. Do you have it set to Photo, Best or economy? Usually this is done in the Epson application and/or at the print window. Higher settings will use more ink.
Sep 04, 2014 | Epson WorkForce WF-7620 Wireless Color...
Epson WorkForce WF-7620 Wireless Color All-in-One Inkjet Printer Logo
582 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
