Question about Samsung SCX-4100 All-In-One Laser Printer
What happen no copy ?
No copy ?
Posted by aasthasht shrestha on
When I make a Duplex copying,it is copied at the wrong position only on the front side.
check that you are using duplex and left binding. also does this happen with other files??? does it happen with different program pdf , word etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 20, 2015 | Sharp Mx-2310u Color Copy/print/scan
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
1410 does nothing when i scan
Check for copying, if copy is happening problem with drivers, reload it. If copy is not happening problem with Scan head, replace it.. Scan head:
Jan 01, 2012 | HP PSC 1410 All-In-One InkJet Printer
My printer cannot scan
Copy is happening? if copy is happening, check for the OS support, reload the drivers with original CD..If copy is not happening, fault with scan camera,replace it or else submit the printer in service center..
Dec 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Copier would not copy, when you press the copy button, nothing happens
Hi:
If the copier is at the ready screen and you press the copy button and nothing happens, Remove the toner cartridge and verify that is is not empty. If it is then the copier will not copy.
Andrew
Feb 16, 2011 | Toshiba estudio 305 Copier
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
When 2-sided copies are made using the feeder,
hi just clean the paper path to solve the problem
thanks
May 11, 2010 | Canon imageRUNNER 5000 Copier
Leaving a dark strip down the middle of the copy
what your copir model? if your model IR3045 replase the drame unite.
Jan 05, 2010 | Canon Office Equipment & Supplies
Problem copying pictures to cd
heelo, i think your cd is bad i.e. unreadable check the cd. and try again.
Dec 20, 2008 | Microsoft Windows XP Home Edition
Try burning the CD by using a different software, like Nero or CloneCD...
Please rate this solution.
Sep 20, 2008 | Microsoft Windows XP Professional With...
Samsung SCX-4100 All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
