Video Cameras Logo
P
Peter Vickers Posted on Sep 17, 2016
Colour TFT display goes off after initial switch on
  • kakima Sep 17, 2016
    Hi Peter Vickers, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
2 Related Answers
Anonymous
  • 14 Answers
  • Posted on Sep 07, 2010
SOURCE: The monitor takes 10mts for
in this power supply filters are faulty. replace them.
pifonski
  • 142 Answers
  • Posted on Apr 19, 2011
SOURCE: HP Colour Laserjet 5550dn. Once
i hope that the problem is not in some of your printer boards, but i have to tell you that you have to expect problems with POWER SUPPLY BOARD or FORMATER BOARD. Please call service for help
pifonski
2answers
How to fix error code 116-321 w c xerox 7345 colour machin
HELLO.. Please click on the link for the solution to your issue.. http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/lynn_f08552ff80c75888
My lcd is hpl1908w its display goes of 5 minutes on first starup and when its displays goes off i on and off the monitor display comes for fews seconds and then goes off again lcd light is green but...
well if your lcd has no bulge capacitors test your tft lamp both top & down of the screen( particularly top) with spare tft lamp. or use another screen to test it. secondly, test the c5607 transistors in the inverter section but if you know how to use spare tft lamp very well , you will easily detect between your screen & the inverter
HP Colour Laserjet 5550dn. Once switched on it goes through memory check; display lights and hp logo on display screen. Then displays on screen "Initializing . . ." Doesn't go any farther - just...
pifonski
3answers
Resolution problem with AOC TFT 185W80PF
Monitors don't need drivers to function. Either you need to configure it or it's dead.
White part of display is a light green colour
it is due to problem with monitor display wire connector, either it is loose and if not visit service center
My monitor has a variety of colors going down the left side of the screen and across the top of the screen
increase colour quality 24 or 32 bit from display properties, if there are no options than u have to install display driver.
Xerox tft 19" model 900w poers up a few seconds, seems riddish in colour, then goes to standby
Xerox tft 19" model 900w poers up a few seconds, seems riddish in colour, then goes to standby? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
200 003 190DTLB5 BH Xerox 860 AB0 190DTLB5 PSH Power Supply Backlight...
2answers
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
