Kenmore 74229 Elite Black Countertop Microwave 2.2 Cu Ft, 1200 Watts Logo
Posted on Sep 16, 2016
How do I set the timer and use the cook function at the same time on my Kenmore microwave model 405
I can't set the timer when the microwave is cooking or cook when the timer is in use.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Mar 23, 2007
SOURCE: Microwave buzzing
It's likely a bad magnetron or maybe the high-voltage transformer. If it's within the warranty period of the magnetron (5 years or less), I would call Sears. In my professional opinion, no one should work on a microwave unless they are fully informed and aware of the deadly hazards and necessary precautions. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Anonymous
  • 38 Answers
  • Posted on May 24, 2007
SOURCE: Model 721.80803400 microwave blank control panel
there is a transformer on front pc board.might need tech to have a looksee
Anonymous
  • 4 Answers
  • Posted on Nov 23, 2007
SOURCE: Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Mar 07, 2008
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • 534 Answers
  • Posted on Mar 31, 2010
SOURCE: Microwave turns on but doesn't cook
There is an inline fuse that is accessed by removing the outer casing. Follow the power line in to the magnatron and you should see the fuse. Make sure the fuse that you replace it with is the same as the one you removed. If this doesnt work then the magnatron has gone out.
Dave
E-1 error on my Kenmore microwave, will not work?
https://homeguides.sfgate.com/cuisinart-bread-maker-error-codes-13409633.html
Error code ERROR 1 presents on Kenmore Elite countertop microwaves with model numbers 56561582011, 16755, 56561584011 or 56561589011. ERROR 1 occurs when the unit has not received enough power to undertake a sensor cooking operation. Sensor cooking is a feature of Kenmore Elite microwaves that adjusts the temperature and cook time of dishes contingent upon information received by sensors in the microwave. In order to perform this function, a microwave must be plugged into a power source for at least five minutes previous to doing so. Thus, ERROR 1 indicates that the unit has not been plugged in for a sufficient length of time.
tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
1helpful
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
GE Microwave wes1384sm2ss quit cooking. it
Owners of a GE WES model might want to look at this blog post.
I have an emerson 900w microwave mw8999sb sn908003050mm. I have tried cooking in it and setting the timer at the same time to time something else that I am cooking. Can it be done with this type of...
The owner's manual is here, and it does not mention that as a feature.
One way to prove that is to press the "Kitchen Timer" pad while the oven is cooking and see if anything happens.
No modern microwave that we know of has this dual function, but it sounds interesting.
Only 1 function works at a time on mco16
That actually sounds like correct operation in that you cannot use the timer while it's cooking.
Assuming yours is model number is MCO160S, you can download your owner's manual here if you don't have it.
Page 19 tells you how to replace the cooktop lights and the cavity light.
67helpful
7answers
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
