Cooling fan for rad not working.. car goes into overheat mode... if relay is bypassed then runs all the time.. does something run the relay.. the problem appears to be on the blue wire side
I can't find the switch so i can replace it
Either the relay has shorted out or the coolant temperature sensor has failed. start witht he relay, install a new one and see if the situation improves, if not then do the temp sensor.
thank you for your response... where do i find the temp sensor on this car
any way of checking to see if it is working
WANT TO CHANGE RATING TO EXCELLANT TY FOR YOR HELP
