The problem may be in the DC jack in the laptop, sometimes solder touch up or DC jack replacement is required. the computer will need to be dismantled down to the motherboard level to address this.
Remove main battery and turn on, next! check the power supply for correct voltage, if okay! sub the ram out one out a time and power on and repeat. If still no result, the DC jack in the laptop is a common issue, suggest a professional to assess.
You can download theLAN and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Try this: log off then turn off lap top, insert the USB devise into the USB port, power / turn on and log in it should show to recognize new hardware and work.
try with an external monitor (connect an external via 15 pin's output of your laptop) if it worked, monitor of your laptop is damaged and you can only take it to a guarantee center. and if it doesn't work: 1- open back lid of laptop. 2- evolve the battery. 3- wait 15 minutes. 4- put the battery. 5- turn on the laptop. and if it doesn't work, take take it to a guarantee center quickly.
With the computer lid closed on the front of the computer on left side there should be a tiny switch that you can turn to the left or right. When it is on a light will illuminate.
