SOURCE: WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
SOURCE: Dryer leaves brown spots on clothing articles.
With the combination of seal gaps and brown spots (streaks) on your clothes, chances are the front (part # 3406129 ~ $26) and rear (part # 279857 ~ $17) drum seals need to be replaced. Run a rag around the seals and check the marks to confirm this is the problem.
Depending how big the gap is, you may need to replace the drum support rollers if they are worn (part # 349241T ~ $24).
The parts are available at Sears. Labor costs will vary depending on where you live and if you're not replacing them yourself.
Let me know if you need more help or information.
SOURCE: leaving brown stains on clothes, messing them up,
If it isn't rust, I suspect cotton can decompose if moist for a long time (in the laundry or machine), causing brown spots. In that case, the spots probably cannot be removed. Or can they?
SOURCE: my palm tree appears to
Unfortunately,no not at this point.You will have to replace them.Next year use 1x2 stakes and build a frame to fit around and over the trees.Staple CLEAR pe tarp and you have an instant temporary green house.A roll of 100yards by 20 feet at Lowe`s is about 80usd,and can be reused.
Where do you live? Fungal disease followed by stress can cause this. Have you had a lot of rain lately?
