Question about Vizio VX32L Television
No picture or sound
TV turned itself off during normal viewing.
Now the Power/Stanby light continually flashing
Posted by datone on
  • 3 more comments
  • datone Nov 19, 2007
    Thanks for the reply-
    Make is a Bush LCD 27TV005
    I have a suspicion it has a 'split' power supply and that may be were the problem is ??
  • datone Nov 20, 2007
    Hi
    Tried powering off for several hours but the fault remains ; I think it is a power supply issue
  • ANGLERAL Feb 15, 2008
    I HAVE THE SAME PROBLEM......THE TV HAS STARTED TO SHUT ITSELF DOWN AFTER ONLY A FEW MINUTES WITH THE LITTLE RED LIGHT FLASHING IN THE LOWER LEFT HAND CORNER. WE HAVE SHUT THE TV OFF AND WAITED PRIOR TO TURNING IT BACK ON AND IT WORKED FOR A WEEK BUT LAST NIGHT IT DID THIS REPEATEDLY. TRYING TO FIND SOMEONE TO WORK ON IT. STAY TUNED
  • jlynn47us Jun 26, 2008
    All the captions show up when tv is on but have no sound or picture. This is a new vizio w32l hdtv 20a. What should we do. Never had a problem before today. Have shut down tv, changed batteries in remote, checked connections, again we can read all captions consistently, but no picture, no sound. Other tv's in the house are fine.
  • Anonymous Mar 30, 2014
    flashes in and out during viewing across the screen
Anonymous
Is your tv a vizio vx32l, if so I would be willing to buy parts from you're tv if you decide to junk it. You can contact me at [email protected]. I want the screen if it is in great shape.
Posted on Feb 18, 2008
VIZIO Hater
I have the same problem with a Vizio 50" plasma
Posted on Jan 09, 2008
Anonymous
  • 203 Answers
Sounds like the unit is in some sort of shutdown. It's hard to pinpoint the issue without knowing the make/model of the unit.
Posted on Nov 19, 2007
  • Anonymous Nov 19, 2007
    If pushing the power button does nothing it may very well be in the Power Supply, as that is the first place I'd look. Have you tried to unplug the unit and wait a few minutes and then plug it back in and attempt to turn it back on?
    If it comes back on for a short bit after a hard reset, that points to something else shutting it down rather than the P/S.
Sony kdl-46w5100 shuts itself off then goes to stanby flashing 10 times
I have the same tv with the same problem, replace the power supply boards and still had same problem, called in a tv repair man and I was told I have a main board problem bu board Watch Dog Timer used to track micro processors, led flashing 10 times cost around $425 parts and service call
Feb 24, 2012 | Sony KDL Televison & Video
Why power/stanby blinks light red
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 19, 2010 | Sony KDF-E42A10 42 in. LCD Television
Tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
PLasma wont turn on
Unfortunately you need a repair man. The power supply is bad.
Nov 12, 2008 | Televison & Video
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Kf60xbr800 internal lamp component, what is the replacement costs for such parts
Go look at your set up timer in menu see what it says some sets will tell you to replace lamp, while other types of DLPs just start turning off and on ,their may also be something wrong with area around lamp too.Read your service manneul or get one on www.free service manneuls.com . ThankYou for using FixYa.Have a Nice Day.
Feb 07, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Vizio VX32L Television Logo
500 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
