Lanier Multifunction B&W Laser - SP1000SF Error Message "Printer Error Motor"
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
SOURCE: dell 5200M laser printer
there is a flag in the output bin that lets the printer know when there is too much paper on top of the printer and it stops so that the papers do not continue to feed out and overflow.
Either the flag is stuck in the up position, in which case you can just gently move it so it is hanging straight down, or the flag has been broken off and no longer functional ( in which case the flag and/or sensor would need to be replaced).
SOURCE: Main Motor Error message on
Hello Don,
One other fix you can try is accessing the hidden maintenance mode. Try this;
You can enter the menu in this way:
Start up the machine with push in the buttons "online" and "cancel"
--You will see the message "Download mode press online key"
Press about 15 times the "menu" key
--You will see the message "Uncheck consumable mode"
Press about 15 times "menu" and 5 times "enter"
--You will see "Press access key"
Press a few enters
Press 3 times "cancel"
Go to the EDC mode
-- you will see "press access key"
Press "cancel"
Go to maintenance and initialize the parts you like to reset.
SOURCE: ''Page too complex'' message on HP color laserjet 2840 Multifunct.
On the printer, hit the menu button
Then navigate using your left arrow button until you see Main Menu - Service, then hit enter
then use the right arrow to navigate to high speed usb and hit enter.
it should now show on, use the right arrow once to change it to off and hit enter 2 times
let the printer reboot and its should be fixed
SOURCE: Dell printer will not print. Receiving message: fuser error
Fuser error usually means that the heater element has blown, or is not functioning properly.
The device will usually lock itself out to prevent any risk of overheating and causing a fire
You will need a technician to fix this
