SOURCE: lcd screen problem
HI, this is isolated within the LCD screen. the input ribbon may be defective or, the entire screen could also be damaged. you will have to replace the lcd screen in this case due to the integrated design. you can confirm my diagnosis by, pulling the battery or plug for 5 minutes. if this screen is still not operating normally after you re insert the battery, this will confirm LCD screen failure.
SOURCE: finepix s5700 date stamp wont show on my computer
Guru, would you describe where in the menu that function can be found, 'cause I can't figure it out.
Thank you.
SOURCE: my FUJI FINEPIX S5700 Digital Camera keeps saying
You may not be able to. However let us try. Reset all menus to default, or factory settings. Another way to do it, possibly is to remove all batteries and let the camera sit for at least 24 hours, then put the batteries back in and try it.
You may need repairs.
SOURCE: hi my finepix s5700 camera
First, download any pics from the card using a card reader if necessary. Then, go into the menu and find "format"...follow the on-screen instructions.
