Question about Yardworks Broadcast Spreader
Adjust spreader opening. knob does not change opening size. Yard works 65 lb spreader
Posted by Itisbrok on
  • kakima Sep 13, 2016
    Hi Itisbrok, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
  • Itisbrok Sep 13, 2016
    65 lb Yardworks spreader, new but knob does not change the size opening as it should.
I have a scots edge guard spreader and need to put on weed and feed at 4 lbs per 1000 sq feet what setting on spreader should I use
Hi Mike:
The setting will depend on the size of the weed & Feed pellets.
The package usually has setting instructions on it.
If all else fails, the rate is 1 lb per 250 square feet.
Mark out an area about 10 ft by 25 ft long.
The spreader cast is about 5 ft, so down and back should use 1 lb.
Set the spreader at a minimal rate and see how far 1 lb goes, then adjust the setting accordingly.
May 22, 2015 | Scotts Garden
What settings to use for grass seed
If you are planning to overseed or reseed your yard, it would be best to use a rotary spreader instead of a drop spreader. When spreading seed set the spreader on 2 or 3, It really depends on the square footage of your yard. If you purchased seed from a local nursery or hardware store, read the bag and it will have the correct spreader setting on the bag. If you just bought a few pounds and the clerk weighted it up for you, you probably can call and ask the clerk for the spreader setting. But I'm pretty sure setting 3 will work just fine.
Sep 14, 2011 | Scotts Company Scotts Turf Builder Classic...
I just bought a new Scott's "Classic Drop" Spreader. I owned a Scott's drop spreader before and the recommended settings on Scott's fertilizer bags always worked great. On...
I am sorry that neither spreader performed as they should have. This is very concerning to us, and we would like to get more information about the spreaders, if you still have 1 the manufacture date would be most helpful to us. It sounds like you could possibly have an over-application of the product as well. If you could call us at 1-800-543-8873, we would be happy to discuss this with you. Stacey at Scotts.
Jun 06, 2011 | Scotts Company Scotts Turf Builder Classic...
How do i calibrate the spreader
Your AccuGreen 3000 Drop Spreader was calibrated at the factory. However, a spreader's calibration may change or slip over time or during periods of heavy use.
You may check the calibration of your Scotts Accugreen 3000 by first adjusting your micrometer setting to 6. Turn the spreader over so that you are looking at the outside of the bottom of the hopper. Use your foot to hold down the trigger (if your trigger has a locking mechanism you can lock it in place prior to turning upside down). With the micrometer set at 6 and the trigger squeezed against the handle, the front edge of the projecting ridge on the shut-off bar should be aligned with the calibration line located on the 2nd or 3rd tooth from the center. Some of the older AccuGreen 3000 Drop Spreader spreader models do not have a raised ridge. On these spreaders, line the front edge of the shut off bar to the calibration line.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and raised ridge or front edge of the shut-off bar meet. If you have any difficulty checking or adjusting the calibration, contact us and we will be happy to help walk you through the adjustment.
Again, thank you for taking the time to contact us and for your interest in Scotts. Please feel free to call us at 1(800)5438873 anytime we may be of assistance.
Mar 03, 2011 | Scotts Company Scotts& Accugreeen 3000...
I have a Scotts Speedy Green 2000 rotary spreader and want to know the proper setting for your Milky Spore 20 lb. bag (granular carrier). I have been keeping it about 50% open (Setting # 9 to 9.5) but it...
I have the same question, but have not found a direct answer. I have calculated an estimate setting of 4 or 5 for the speedygreen 2000. The Milky Spore is very simular to the fertilizer that I use. Milky spore says that 1lb covers a little over 300 square feet. My fertilizer says that at a setting of 4 it is spreading 2.6 lb per 1000 square feet (almost 3 lb per 1000 sq ft or 1 lb per 333 sq ft).
Now I may be totally off, but just bought the Milky Spore today and will apply tomorrow. I may look some more tonight to see if I can find an answer. I felt it was kind of bad that the back of the Milky Spore suggested only using a drop spreader!?
Sep 06, 2010 | St Gabriel Laboratories Milky Spore Lawn...
Will bayer advanced 24 kill fleas and ticks, or just grubs?
It did a great job on grubs in my yard but read the bag, it says what it will kill or contact Bayer.
May 26, 2010 | Bayer Advanced 24 Hour Grub Killer Plus...
I borrowed an older craftsman walk behind lawn spreader from my neighbor to apply Ace 5M crabgrass preventer. There is no model number on the spreader. It has settings from 2 to 16. What do these settings...
Well, they represent the size of the opening through which the product falls before hitting the spinning spreader part. A larger opening allows more product though; a smaller opening allows less.
I don't know if these are standardized across makes (I don't think they are). The best thing you could do would be to look in the hardware section next time you're in town and set a display model to the setting called for by your product (Scotts always lists the settings for their spreaders on their product), and then eyeball the size opening you get, then approximate that on your machine when you return home.
Or you can just pick the middle setting and do a test run and see if you think more or less should be applied, then adjust accordingly.
Mar 27, 2010 | Craftsman Garden
Scotts 3000 spreader needs calibration?
I found the manual that came with the spreader.. recalibrated it and it works fine.
Apr 28, 2009 | Scotts Company Scotts& Accugreeen 3000...
Fix the distribution propeller on a broadcast lawn spreader
back yard fix
use the right size nail
use the right size split pin
use the right size bolt
Sep 10, 2017 | Garden
Max Paper Weight
Here ya go...
Tray 1: (standard) 16 lb. Bond – 80 lb. Cover (60 – 220 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, business cards, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards, Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, A5, A6, B5 JIS, B5 ISO, 3 5 in. Index Cards, custom sizes; Envelopes: #10 Commercial, DL, C5, #5 , #6 , Monarch, Booklet, Lee (A7), Choukei 3 Gou, Choukei 4 Gou, custom.
Tray 2: 525-sheet tray (standard) 16 lb. Bond – 28 lb. Cover (60 –122 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards,Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, B5 JIS, B5 ISO; Envelopes: #10 Commercial, DL, and C5.
Tray 3: 525-sheet Feeder (standard on DX) Same media weights and sizes as Tray 2.
Tray 4: 525-sheet Feeder (optional) Same media weights and sizes as Tray 2.
Nov 12, 2007 | Xerox Phaser 8400 Laser Printer
Yardworks Broadcast Spreader Logo
298 people viewed this question
Top Yardworks Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
