SOURCE: CD opens and closes perpetually. CD won't play.
likely yes. does not sound like coincidence. try this: search ebay for an AS-IS item for $1 and use it for part-swapping. first to swap-the main circuit board holding the micro chip.
SOURCE: CD tray repeatedly opens and closes
is this a yamaha 5 disc changer, table. not the cartridge type...
SOURCE: Xbox does not read discs.
i have the same problem.. but mines a little. differnt.. any disc i put in it wont read.. how do i fix that?
SOURCE: my xbox 360 cd drive keeps on opening and closing.
Your having a dvd drive problem Im taking a guess but i have fixed many like this before. What you need to do is take your xbox360 apart. You can find a video how to do this on our site http://www.xboxmodshop.com next you want to remove your dvd drive take out the four screws on the bottom and remove the top cover. Now make sure your looking at the spindle where the game rest in the middle of your spindle you will normally find two magnets, but in your case your probably wont. Yours are probably stuck to the top of your drive cover. You need to remove them and superglue or epoxy them back in the middle of your spindle.After completely dry put everything back together it should play normal.I recommend a inter-cooler so this wont happen again.
Thanks http://www.xboxmodshop.com
SOURCE: CD Rom Drive opens and closes over and over won't quit
it happens often because of some materials or cd broken pcs try to clean it carefully
