IT PLAYS MUSIC FROM MY IPHONE 4 WHEN I DOCK IT
SOURCE: ipod dead after using altec lansing im600
YES.. it possibly the caused why your ipod was damaged.
SOURCE: inmotion speeker dock wont charge new ipod touch
This is because you are using different generations.
If the dock was only meant for 1st generation, then itwill only charge 1st generation. It's how they make their money.
SOURCE: My Altec Lansing Inmotion used
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
SOURCE: my altec lansing im600 won't
Hi Take out the battery from it. The battery is accessed by removing just two screws with a cross head, and pulling its cover off. Disconnect the battery and plug it back in. This will work. Also try this... Detach the power adaptor and battery Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
Also remove any external USB devices
Hold the ON switch in for 30 secs (dispersing all internal power)
Put the power adaptor in ONLY (confirming that the power source is Ok too)
Try turning on
If it works
Turn off, and put the battery back in
Turn on
SOURCE: have Altec Lansing im600 and
Hi! Are u able to play anything from the speakers from ur iPhone 4? Mine charges, but won't play
