Question about Minolta Cameras
What is the biggest size memory card for my Dimage A1 Minolta Camera?
What is the memory card size for a Minolta Dimage A1 camera?
    Scholar:
  • 136 Answers
An older camera, the DiMage A1 came with a 16mb card. Some cameras are picky about which cards work best. Compact Flash cards are sold in different speeds and your camera may work faster with a faster card. This camera can use Compact Flash type I or type II, and is compatible with the microdrive card. Since this camera was introduced the capacities of Compact Flash cards have increased dramatically so I believe you should be able to use a larger card with no problems but I would check out some of the online photography sites to read about other's experiences. Here is one good resource:
http://www.imaging-resource.com/
Hope this helps!
Posted on Sep 13, 2016
Minolta dimage E323, 3.2 mega pixels i use a pny optima sdhc 8 gb and it tell ing me to reformat
This camera is NOT suitable for SDHC type cards, only SD cards with memory size till 2GB.
Sep 03, 2010 | Konica Minolta DiMAGE S414 Digital Camera
Am I able to use a 2GB SD card in my Konica Minolta Dimage G400 camera or could this cause problems.
This camera has been discontinued, and is no longer sold as new. There are still vendors that sell accessories for this camera including batteries and SD memory cards. A google search of "dimage g400 memory" reveals a number of retailers that sell SD cards of varying sizes up to 2 GB specifically for this camera.
Going beyond 2 GB however, will probably give mixed results, as most cards 4 GB (the next size up from 2 GB) are SDHC type cards. An SDHC card looks identical to the SD counterpart, but is manufactured to a different specification. The SDHC specification was developed after you camera was made, so use of cards bearing the SDHC mark is not supported.
I hope this helps!
Oct 30, 2009 | Konica Minolta DiMAGE G400 Digital Camera
Minolta Dimage S414 camera doesn't like a new 4GB CF card
Check your manual to see if your camera accepts a card that large.
Aug 30, 2009 | Konica Minolta DiMAGE S414 Digital Camera
Camera doesn't acknowledge card when inserted into camera
Hi
Whats the capacity of your memory card? check for compatibility of card, since memory cards that have 4gb to 8gb are not compatible with some cameras. check as well from your cameras manufacturer if they have a firmware that will support such cards for your device/camera.
Hope this helps
May 10, 2009 | Konica Minolta DiMAGE A1 Digital Camera
Memory card size
I have a Z1 and I use a 2Gb SD card. The new SDHC 4gb don't work. I bought one but was able to fit it in my daughters camera.
Feb 12, 2009 | Konica Minolta DiMAGE Z1 Digital Camera
Same PINK problema!
Hope you still have the camera. If so, Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
Aug 22, 2007 | Konica Minolta DiMAGE A1 Digital Camera
Pink screen
This sounds like a defective Sony CCD issue. If so, Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
Aug 08, 2007 | Konica Minolta DiMAGE A1 Digital Camera
Is it possible to control the DiMAGE A1 from the PC? (when the DiMAGE A1 is connected to PC.)
Yes, it is possible to control the camera from PC with "DiMAGE Capture".(sold separately)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Is the DiMAGE A1 equipped with detail zoom function?
Yes, the camera features x2 digital zoom. (Digital zoom does not work in RAW setting) When operate the digital zoom, the imaged size will be changed as follows: Setting image size 2560X1920,2080X1560 and 1600X1200: to 1280X960 Setting image size 640X480: No change
How long does it take to boot the camera?
Start-up time for the DiMAGE A1 is approximately 2.2 seconds in recording mode. It depends on the type of CompactFlash card.
Cameras Logo
133 people viewed this question
Top Minolta Cameras Experts
 Larry
Larry
Harrie
ray gallant
Are you a Minolta Camera Expert? Answer questions, earn points and help others
