Question about Belling Kitchen Ranges
Belling range cooker main oven not working other oven works
Posted by Michele burden on
Mister Danger
  • 5,631 Answers
If you have no other clue and you have no personal experience repairing a ranege cooker, call a repair service. Messing with cooker0s wiring might be dangerous.
Posted on Sep 12, 2016
5 Related Answers
Anonymous
SOURCE: Lofra MXD96AMFE/C Dual Fuel Range Cooker
Hi
The timer on our Lofra MXUD76MFE broke about 2 months after the 12 month warranty ran out.
Being a bit of a fiddler i took the top off the cooker to access the timer (not that difficult) when i ispected the timer i was astonished that it had lasted the 14 months it had such was the quality of it.
The timer was easy to set to ensure the cooker worked but unserviceable to restore the timer mechanism.
I thought given that it was such a cheap looking part (even allowing for the exorbitant price of parts) it would be worth replacing.
Came across the new appointed distributor - Premier Appliance Brands - based in Warrington (01925 248980)
They gave me a part No of 03010631 but didn't have stock and initially could not give me a price. i left it a couple of weeks and rang back this week.
They quoted £77 - needless to say i didn't order it
Posted on Nov 30, 2007
Anonymous
SOURCE: main ovens dont work
if the clock is not set the ovens wont work,they dont have to say the right time but they do have to have a time. to set the clock hold the hand button and the clock button(first two buttons),and then plus or minus to set the time
Posted on Feb 05, 2009
Anonymous
  • 3 Answers
SOURCE: main oven won't work
On ours you have to use the the timer controls; press the button with a hand symbol and the one next to it with a "-" symbol at the same time. Try a combination of the buttons on yours if this doesn't work. Weird, and took me months to figure!
Posted on Feb 15, 2009
Anonymous
  • 13 Answers
SOURCE: User Manual for Belling Electric Cooker
The clock is flashing zeros because you need to set the clock timer.To do this you need to press and hold in both of the the cook period and end time buttons together, then with both buttons still held in , press either the "+" or "-" buttons to set the correct time of day
Posted on Apr 21, 2009
Anonymous
SOURCE: TECNIK 1285 RANGE COOKER
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
Posted on Mar 30, 2010
I have a Belling 335 everything still works apart from the actual oven part? What could this be and is it fixable??
check your timer,if it has a programm set(by accident)the oven will not work until this has been cleared,if your not to sure then switch cooker off at the cookers main switch on the wall.leave for a few mins and switch back on this should clear any set programm,good luck.
Nov 13, 2012 | Belling 335 Electric Kitchen Range
Old belling classic cooker,oven door catch has
my oven done the same so i bought some strong magnets and put one in each corner.
its fine now.
Sep 03, 2009 | Belling 644 Electric Kitchen Range
Convert my belling DB90
You will have to change the orifice to accomodate lp gas.
Feb 03, 2009 | Belling DB90 Electric Kitchen Range
Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Nov 23, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
268 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Lawrence Oravetz
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
