Polaroid PoGo Digital Photo Printer Logo
Question about Polaroid PoGo Digital Photo Printer
The images printing my pogo printer are much ,much darker than the image on the camera. Is there anything I can do to improve the brightest?
I always use the blue sheet to clean the machine before printing..
Posted by Sophie Colgate on
4 Related Answers
Anonymous
SOURCE: Polaroid PoGo Digital Photo photographs streaky with purple edge
TO CLEAN PRINT HEAD, TAKE AN A4 SHEET OF PAPER CUT IT TO SIZE FOR THE POGO,BUT MAKE IT (3) THREE THIKNESSES THIK, FEED IT IN UNDER THE PRINT HEAD AND CLOSE LID, WHILE THE PAPER IS BEING EJECTED PUSH UP ON THE PAPER THAT IS BEING EJECTED WITH YOUR FINGERS, YOU MAY NEED TO DO THIS A NUMBER OF TIMES, BUT IT WILL CLEAR THE STREAKING. IT WORKED FOR ME AND MY POGO DOSE BRILLIANT PRINTS.HOPE THIS HELPS PEOPLE. JB
Posted on Feb 25, 2010
Anonymous
  • 7 Answers
SOURCE: Pogo images not appearing paper comes white
Be shure that the part to be printed is facing you and the "polaroid" logo is facing down
Posted on Mar 11, 2010
Anonymous
SOURCE: wont print from digital camera
Look in your camera settings and change the connection from USB to Pictbridge. If that's possible then you should be able to connect.
Posted on Jan 01, 2011
Anonymous
SOURCE: hi, my polaroid pogo instant mobile
not sure if you've fixed this problem but I'm having same problem too. The picture are so dark I can't really see the image. Quality is so different from the videos I see on youtube. I test 10 photos and still doesn't work
Posted on Apr 17, 2012
Printer Buzzing and not printing
Hello. It sounds like the printer head needs to be changed.
10helpful
3answers
Samsung galaxy s cannot get pogo printer to print!!It say it is paired but not connected
Download the "Polaroid Pogo App" from the Android Marketplace. This will solve the problem of the Pogo rejecting your phone. It also has other features like different "frame shots" or printing one picture over 4 sheets. Best of all - it's free!
1helpful
Canon LBP5000. The printer has stated to print a shadow image of the darker parts of the print. Not always from the start but after some prints. The shasow image can also be from the previous print. It is...
Had the same problem with LBP5000. Used the Cleaning Utility(Options/Cleaning) in the printer software, had to run it several times, the shadow did not go away the first time. Looks all right now.
Hope this helps.
Thor.
2helpful
2answers
8helpful
2answers
I cant print using my phone even tho it has bluetooth and the pogo is listed as a device
LG phones seem to send images with characters other than 0-9 and A-Z in the image filename. It looks like either the Pogo, or the LG phone bluetooth software doesn't accept this (I see "disconnected" if I try to print an image with a filename like that)
This solution "works" to the extent that renaming the file helps, though I don't know how to avoid these characters appearing in the filename of the photo in the first place :
http://www.fixya.com/support/t3651208-kp500_lg_cookie_compatible_pogo
I have not used my Phaser 6110 for about 3 months, and now print quality is bad. It appears to be only the black that is affected. print quality is faint although slightly darker down one side. I have...
This sounds like the doctor blade within the black developer unit inside the image unit has become contaminated. This means that not enough black toner will be attracted to the developer roller. This usually manifests itself as feint thin lines of print running vertically through the text being printed. This can be repaired and is a known issue with this image unit.
If the printer is in warranty tell them you want it replaced, if not then take the image unit back to the supplier you bought it from and demand a replacement.
Photos printing too dark
try editing the photo.. more brightness, contrast etc etc.. see if it will also print brighter... if it still prints the same i guess its time to throw the printer back to epson
Improving bar code image DPI for a darker output
Datamax Program Language (DPL) uses pcx and bmp graphic formats. The Adobe image must be opened in Adobe Reader and print using a windows driver. Use the datamax windows driver from www.seagullscientific.com
HP Photosmart C7180 All-In-One
Hi try coping a document from the machine and see if the copy comes out with these lines. If it does then the machine scanner unit is faulty and will need replacing. If not then the likely thing is that the printer device drivers are incorrect or faulty. reinstall the drivers or download a up to date driver from hp.com for the other printing darker try changing the graphic processor mode in the driver. Goto printers and faxes right hand click on the printer icon and select properties.
Once in properties select the advanced tab at the top of the windows within this tab at the bottom select print processor. Once in there choose another graphic mode OK close and test if no improvement select a different one and so on until improvement is achieved. if no improvement then reinstall the drivers if you haven't already.
Hope this helps
Thanks J
Top Polaroid Office Equipment & Supplies Experts
Steve Nordquist
Steve Nordquist
W.L.
Clive
Clive
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
