Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instructionnot my words. The link to the pdf for this is
http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdfyou want page 22.
Problem Check Point
The driving of the wheelchair is
too slow or insufficient, the statusindicator lamp flashes slowly
Batteries are exhausted and need to be recharged1 flash
The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.2 flashes
There is a bad connection to the motor.Check all connections between the motor
and the controller.3 flashes The motor has a short circuit to a battery
connection.4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes
The controller is being inhibited from driving; this may be because the battery charger is connected.7 flashes
A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter8 flashes A controller fault is indicated. Make sure
the controller connections are secure.9 flashes
The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Brand, model, number, PLEASE!!!!
