Used daily.
SOURCE: tiger triumph 2008 brand new wont start... help
ok
you have a problem with the starter not turning the engine. so we probily not sending a signal to the starter.
you realy confused me when you started talking about gas and choke?
if the engine doesnt turn over none of this even matters.
these new bikes have many safety features .
you have a sensor for netural and you have a sensor for your kickstand and a sensor for your clutch
and all of these have to be workinf right for your engine to turn over.
so with your kickstand up and the bike in netural and the clutch lever pulled in
it should turn over and start.
when it doesnt you need to check your wiring to the switches one might have come loose.
or could be a bad switch.
let us know what you find
paul
SOURCE: i need a complete wiring diagram for a 1998
Become a member (if you aren't already) at tigertriple.com and post a want in the Steamers section. When I see it, I'll PM you with a copy of the schematic.--Sinn'
SOURCE: Can't start my Triumph tiger 955i 2005
let is sit for a day and dry out. you probably got moisture into the spark plugs, or the distributor, or the wires. if you have a battery charger, charge the battery while you are waiting.
SOURCE: '04 Triumph Tiger clutch cable
If it is running alone the back bone then yes you will have to remove the tank.
SOURCE: not starting/firing. spark plugs? 1996 Triumph
First, do you have fuel, and then do you have spark at the plugs. Check the source.
