Exercise & Fitness Logo
J
Jean-Baptiste Baetsle Posted on Sep 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a problem with my treadmill Stex 7020t; when I use the powerbutton the treadmill makes a beep; sounds and wont start. On the display I read stex-7020 tuxx 13. Can anyone please help me?
Stex-7020 tuxx 13 default
Electro Med Services
Level 3:
  • Master 6,694 Answers
  • Posted on Sep 10, 2016
Master
Level 3:
Answers
6694
Questions
Helped
1872447
Points
21433
If you wish to get some details about treadmill repair; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Testimonial: "I can't find a solution to the problem of my treadmill in this article..."
1helpful
I need a manual for stex 8020t treadmill
Unfortunately no manual is available online but if you contact http://www. synergyfitness. com.au/ they should be able to help you
Stex treadmill about error 2
adjust the Speed sensor, see the diagram, clean it, test for open or faulty, and tight the connector very well.
Lube the deck belt, see the video, lube the rollers bearing front+back too , test the drive belt motor and replace the belt if necessary. God bless you
However you must try to Run the software calibration after your fix it.4d80cf2e-89d9-4476-902b-88e5991886e8.gif
1helpful
In Stex X6 treadmill speed up key not operating above 1.0km/hr
Hi I am using stex x6 machine 09 speed button not working
2helpful
Error code 1
I am the same Problem with Stex 8020 T Error Code 1
Treadmill Stex 8020 when switched on immediately increases speed on board (without touching buttons) until it reaches 250km...the belt isn't moving when this is happening and pressing + or - or other...
If it reaches 250km then I suspect that the upper electronics is not functioning properly contact the distributor of Stex and If under warranty they sould cover it,but send out a servicer
2answers
Belt is slipping, even on the lowest power.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
As far as the manual, I have not been able to found it anywhere yet.
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
