SOURCE: how to reassemble door catch of indesit tumble drier
Very difficult to explain with out pictures, the pin should go through the spring it really is a matter of fiddling until you get it right or go back to where you bought it from and ask them how it goes.
SOURCE: Have to reassemble VHS-C cassette
Tried searching for a diagram but didn't find one. Usually the spring goes to the plastic door protecting the tape. If the door isn't retacting, you should remove the door altogether and the tape should work as long as it is moving properly when you turn the take up roller on the tape by hand.
SOURCE: cannot reassemble brake band assembly to clutch drum
The brake was engaged when removed. The Illustrated Parts List (IPL) here shows how the majority of components fit together. The brake needs to be released to clear the clutch drum.
Secure the clutch cover (it requires quite a bit of force), with a couple of blocks of wood, in a large vise or a C-clamp on a work surface.
Use a pair of pliers or a crescent and rotate the spoked part CW until it latches. This one is latched.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
SOURCE: Reassembly instructions
That little screen that lies at the bottom of the bucket needs to be snapped out and the washer replaced. You have to unscrew the bottom, carefully remove the spring loaded lever, ( don't loose the spring) After fishing the lost rubber washer out of the hole, I used a screw driver or other similar item to pop the screen out. ( use care not to poke a hole in screen.) Next replace lever and spring and push the Star ended piece through the bottom and THEN fasten the washer. Replace all excess pieces and it should be fixed provided the washer isn't badly worn. This is the only way I know how to fix it after countless different web pages and searches.
