INDESIT IDL 530 DISHWASHER IF I TURN IT ON WITH THE DOOR OPEN ITS FINE ONCE I CLOSE THE DOOR IT TRIPS THE RCD HOUSE FUSE,
THE DOOR CATCH WAS REPLACED AS THE OTHER ONE BROKE A FEW DAYS AGO IT TRIPPED THE RCD LAST NIGHT AFTER DOING A FULL CYCLE, AND NOW IF I TURN IT ON WITH DOOR OEN ITS FINE CLOSE THE DOOR IT TRIPS THE RCD
Re: INDESIT IDL 530 DISHWASHER IF I TURN IT ON WITH THE DOOR OPEN ITS FINE ONCE I CLOSE THE DOOR IT TRIPS THE RCD HOUSE...
Is there any service center of this company.
Testimonial: "its out of warranty just took the door cover off all wires are inlace took off the inspection plates at the bottom of the dishwasher the is some water laying there"
You will have to find the component in the machine that has gone live to neutral,live to eath or neutral to earth if it is protected by a RCCBO. Check on the back of the printed circuit board for "BLOWS" black marks blown components.
Disconnect or turn the breaker off which ever it's easier, then make sure you open the door, and it's closed make sure you push the door on the center of the door to make sure the microswitch gets alignned, get the power on, and press cancel botton once, just to reset any cycle. good luck
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
when i attend dishwashers that have lost power to some part or short out at any point, i always check for broken wires inside the door skin, the wire harness inside the door skin gets hot and cracks with use when opening the door all the time, alternatively there could be a short on any of the working parts,
unplug each part one by one and switch back on to test, when you have unplugged the faulty part the switch will not trip, replace as needed
work with safety keep fingers out and unplug from power supply when disconnecting parts for testing
hope i have helped if so please rate me
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections. f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
the heater is faulty(shorted) and check that the hot water is getting to the appliance as the buzzing is the soliniod being powered but the water is not passing through
