Question about Power Acoustik Car Audio & Video
Hello, I have a power acoustik PD-712 7" lcd in dash head unit. My problem is, all of my power is connected correctly fuses checked as well . Why is my 7" LCD not producing a image or even turning on?
Posted by Levi Bennett on
bigdawg7299
  • 2,559 Answers
Assuming you have all the connections correct and there is the appropriate signal (12v, ground, etc then tour unit is defective.
Posted on Sep 06, 2016
5 Related Answers
simplemitch
Mitch
  • 752 Answers
SOURCE: NO POWER TO PIONEER HEAD UNIT
Disconnecting the cables shouldnt have hurt it. Make sure you got the plugged back in ALL the way and try again. Post results here.
Posted on Sep 12, 2007
SOURCE: play while driving
in the USA that is ilegal but if you wanted some of my colleagues put the parking cable of the stereo to ground.Good luck
Posted on Apr 03, 2009
rusty2c
  • 239 Answers
SOURCE: Clarion VRX755VD LCD problem
check that you havent squashed the radio into the dash cause if its squashed in the dash the screen wont come out maybe get it out so the radio is in your hand then press the open button if it comes out then thats what it is if it doesnt its your mechanism
pls rate
Posted on Aug 18, 2010
ahaviland28
amber haviland
SOURCE: Power Acoustik PTID-4007
I would check if your vehicle has a factory amp. Often times they must be bypassed. I had a similar problem with my 1998 Mits. Eclipse Spyder. I had to wire all the speakers directly.
Posted on Dec 25, 2013
Terry Corrow
johnny rebel
  • 10875 Answers
SOURCE: POWER ACOUSTIK PD-103B In-Dash Single DIN DVD AM/FM Receiver with 10.3-Inch will not play movies from s/d card or usb port
its not supposed to do that,read your manual,it only reads memory cards,,it plays dvds
Power Acoustik PD 103B
Posted on May 30, 2015
How do i stop a power acoustik pd-450 from randomly shutting off? Ive checked connections and wiring all is good, the power supply is good as well
how random is it? Make sure the radio is grounded properly. Look in the pin outs in the harness and make sure there is a ground there. Also, you may have 1, 2, 3, or 4 bad speakers. A short in any one speaker will send the radio in protect mode. Also, If your radio is seeing less than something around a 3ohm load (technically 4) it will protect itself as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Dec 26, 2014 | Power Acoustik Car Audio & Video
Screen protective on the front of it its cracked
I'm afraid the thing you call front glass is the tough screen once it is cracked you need it to be replaced. For an expensive and new tablet I would go to a phone store and ask them what it will cost. For an old or cheap tablet I would buy a new one. Anyway a replacement could cost up to 200 dollar. So don't forget to ask what it will cost in advance. Just to avoid surprises.
Jul 25, 2014 | Power Acoustik PD-931NB In-Dash 9.3" Inteq...
How do i fix my Power Acoustik LT-980/2 car amp, it keeps on going into protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you
Aug 10, 2011 | Power Acoustik LT-980/2 Car Audio...
I have a jl audio e1200, and everything's been connected correctly. it says that there's power (as indicated by the green LED) but there's no output. what do i do?
Hello codyr25,
First of all, you need to isolate what is causing the problem. No output (sound from the sub) could be a defect in the 1) Wiring, 2) Head unit, 3) Speaker(s), or 4) The amp itself.
Start to systematically eliminate the possible causes. Connect your subs to a known good system. If they work, it's got to be something else. Check the RCA cables from your head unit to the amp. Check the speaker wiring. Check the amp on-board fuses.
Make sure that you have output from the head unit. With multiple RCA jacks, it's possible to plug your cables into an input rather than an output (in the dark, behind the dash). If you have more than 1 set of preamp outs, try another set.
Hope this helps.
May 15, 2009 | Car Audio & Video
Power off issue
Hello octoberburni,
No it is not normal for the amp to stay on when you turn the ignition off. And yes, it will definitely drain your battery if this condition is not corrected.
Use a multimeter set to volts and check between the ground connection (right connector) and remote turn-on connection (center connector) on the amp itself. You should have approximately 12V when the ignition and your head unit is on. And 0V when they are off. If you measure voltage when the ignition and head unit are off, either the incorrect wire is connected to the remote terminal, or the defect is in your head unit. If you measure OK, that is voltage present when ignition and head unit are on, and no voltage when they are off, then the problem is most likely in the amp itself. If you find voltage on the remote wire all the time, check to see that it is coming from the correct output from the head unit. Most aftermarket head units use a blue or a blue/white wire for the remote amp turn-on lead. Many (most) stock OEM receivers do not have a remote amp turn-on lead. But they may have a power antenna lead which will serve the same purpose. In any case, just insure that the correct wire is connected to the amp. It should have voltage when the head unit is on and no voltage when the head unit is off.
In either case, if everything else is still working with the amp, you can simply wire in a manual toggle switch to turn the amp off or on whenever you desire. A SPST (single pole-single throw) toggle switch is what you need. If the problem is in the head unit wire, put the toggle switch inline with the remote wire and mount it somewhere handy on or near the dash. If the problem is not in the remote wire, you'll need to put the toggle inline with the main power wire, the one marked "12V" (left connector) on the amp. In this case, you need to make sure that you have a heavy duty toggle switch, one that will handle more amps than your primary fuse. You may need to look under the hood for the fuse to check it's value.
Hope this helps.
Apr 18, 2009 | Car Audio & Video
Fan on amp runs constantly. will this drain my battery?
Yes, and would imply that the amp is powered up all the time.
You should correctly wire your system by
1.Connecting the constant 12vdc input wire to a constant 12vdc source to power the in-dash head units memory.
2.Connecting the switched 12vdc input wire to a switched 12vdc source to power the head units primary functions.
3.Connecting the remote output wire (typically a blue wire) from the in-dash head unit to the correct terminal on the amp, so the amp will only power up when the head unit is on.
4 Remember to run the signal (speaker) wires in a chase separated from the amps power wires, so as to avoid a buzzing noise in the speakers.
5. Always use an in-line fuse on the amp and the head units main power wires.
Note: A properly powered amp will produce a better sound quality then if it were under powered, so be sure to use the proper wire gauge as your amps power supply.
Good luck
Aduz
Mar 22, 2009 | AudioBahn A2002T Car Audio Amplifier
Power Acoustik PTID-4007 Okay, so I checked my radio fuse, it's fine. Checked for constant and acc 12v. and they are there. fuses on harness are good. I spliced my adapter harness onto the PTID-4007...
i have Power Acoustik PTID-4007 my problem is not turn on lcd not out audio but yes is take cd and out cd, the screen is move in three postion. help me please
thanks
Mar 08, 2009 | Power Acoustik PTID-4006T Car Video Player
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Car Audio & Video Logo
383 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
