Cooktops Logo
A
Anonymous Posted on Sep 05, 2016
PIC645F17E (Bosch) electric cooktop show error code er22. What does it mean ? How to repair ? Please help me ! Thank you !
Marvin
Level 3:
Top Expert:
  • Cooktops Master 85,242 Answers
  • Posted on Sep 06, 2016
Marvin
Cooktops Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29049342
Points
266281
The error code you posted is not listed anywhere. There is the error code "Error" for the oven which means oven overheating. If that's true then the problem is a bad oven power relay board.
This part has been discontinued. Bosch probably replaced it with a different part but I was not able to find the correct part number. You can talk to APP CSR and they will help you to locate the correct part.
5 Related Answers
A
Anonymous
  • Posted on Sep 06, 2008
SOURCE: error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Anonymous
  • 338 Answers
  • Posted on Dec 04, 2008
SOURCE: Broken glass for 5 burners electric Bosch cooktop
If you can give me the model number I can give you 3 places and there prices. The model number should be located on the bottom of the unit.
Anonymous
  • 1998 Answers
  • Posted on Jan 24, 2011
SOURCE: My cooktop is showing f156
You haxe a flmction error code. X,_rite down the "F:- - -" and
touch the _) (CONTROl, I,OCK) pad. Disconnect power to
the cooktop and then reconnect.
if this doesnt work then you would have to call for a technician looking like you might have a problem with the control if you have any further questions message me back Thanks Rick if you cant unplug your unit shut off the breaker for 5-7min
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Sep 25, 2012
SOURCE: error code er26 & er42 for a bosch cooktop
Do this and follow the common sense. God bless you
Lower motorized latch will not lock; Defective or jammed lower oven door or latch switches; Defective latch motor or its wiring. 1. Check P24 connector on the power board.
2. Ensure door latch switches are operating properly.
3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
4. Check P10 connector and check if latch motor wire pinched to the appliance chassis.
5. If F42 persists, replace power board.
Anonymous
  • Posted on Oct 07, 2012
SOURCE: net7552uc bosch cooktop error codes 26 and 42
This may be malfunction of the main electronic board.http://www.ifixit.com/Wiki/Edit/Bosch_NET7452UC_cooktop
My AEG 66300KT-an electric cooktop shows E8 error. What it mean and how to repair it?
even look on google
https://www.coolblue.nl/en/advice/zanussi-aeg-induction-cooktop-error.html
Bosch cooktop Flashing F9
again.
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair.
From the Manufacturer
Error code er22 is showing, any ideas?
Google search your manufacturer make and model and the words error code 22. You can find your answer in the search results.
May 02, 2015 • Cooktops
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
1helpful
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
6helpful
3answers
NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
Problem: Error codes 26 or 42 after turning on too many heating elements.
Potential issue: Damaged main electronic board
Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
Root cause: Dying/blown electrolytic capacitor on the main electronics board.
Solution:
1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
3) Remove all screws around the metal housing using a torx screwdriver
4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
6) Next open the black plastic cover by removing four Torx screws.
7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
10) Reassemble and done.
1helpful
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
