Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
For my 32" Vizio 003, 006, and 012 all worked, granted your don't get all the functionality but it changes channels and for some reason "003" makes my play button cycle through my hdmi inputs!
I recommend trying the auto-code search to find one that works for your TV. This will search through every TV code it knows, and if none work, unfortunately it cannot be taught new codes.
To have the remote try each TV code it knows one at a time, follow these steps:
Turn on your TV.
Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
Press the TV button on the remote so that the LED blinks once and then remains solid red.
Press the ON/OFF button slowly and repeatedly until
the TV turns off. The LED will blink once each time you press the
ON/OFF button.
Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
Get the 8.00 rca universal remote at wal mart (model rcr312w) follow the auto scan instructions and it will work. I just had this same problem, bought 4 universal remotes and this one worked!
If the remote is infrared (IR), you'd need the codes if the Verizon remote is not a 'learning' remote - in other words, facing the two to each other and transmitting/receiving between them. So, assuming the Verizon is not a learning remote, you'd need the IR codes. Some can be found in the back of users manuals but if not, contact the manufacturer and ask for the codes. They'll usually send them to you in a file.
The input jacks on a 555 are a standard gold plated, high quality jack. looking around the net, you should pay no more than 7-10 dollars each ( or just get originals from Adcom. ). What is your comfort level with electronics?. Can you solder properly?. I cant answer this without more info.....thanks...Good luck...Rob
I have timewarner and programed my remote with code 1229 but it dosent support all functions. I can
run the dvd and the volume. Hope this will work for you.
If pushing the power button does nothing, the unit is probably in "protect mode". This means there is an internal problem and will require professional service.
