SOURCE: Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
SOURCE: what is a F7 code on the display mean
An
F7 error code could be an inverter board failure. Anything else that
prevents microwave energy may also cause an F7 error, and must be
checked. The technician should perform the following procedure to test
for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you don't find yours,
or if you want to look at it without disassembling the oven, you can
download it here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: I dont have the manual
The manual can be downloaded here:
The second pdf in the list is the long form of the instructions.
https://portal.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM
.........then see page 12 for the meaning of the symbols.
Hope this helps!
