Washes ok but makes noise
Check for debris in the pump impeller. Your owner's manual will describe how to
1. Remove baskets
2, Remove wash arm
3. Rotate (inner) lock ring on stainless steel bottom plate to release and remove it.
4. Rotate top impeller by hand to feel for rough spots indicating debris in lower impeller.
5. Rotate motor assembly lock ring to release rotor assembly and clear debris from sump.
6. Reassemble in reverse order and check operation.
This can also occur with a drawer that is not run often (less than once or twice per month) and indicates a dry bearing surface. Most often running a rinse and hold once or twice frees this up and corrects the problem. Drawers work best when operated once a week or more.
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
SOURCE: My dishwasher is making a very loud noise during the wash cycle.
It is probably a dying recirculation/drain pump. It serves both purposes so is only off when the drying cycle starts. If the bearings are going bad the seals will probably fail soon too since they will be more stressed by any wobble in the pump shaft due to wear.
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
SOURCE: Dishwasher making loud humming noise
The most common cause of the hum/grinding sound, and often poor cleaning - is a blocked filter or debris stuck below that filter.
Pretty easy fix:
Get a phillips screwdriver near by. Pull out the lower rack (the upper rack can come out if you pull the little gray thingeys on the front of the upper rails.)
Remove the lower spray arm -- just pull it straight up.
Remove nine silver screws from the sump area that holds the filter down. Pull the filter up and out. Rinse the filter as best you can.
While the filter removed, with a flash light inspect all over the sump area - looking for stuff that should not be there and clean it out. Watch out for broken glass!
Replace the filter, screws and the spray arm. Fire it up and check your results!
Good Luck!
