Does a Roku Stick Work on Any TV?
The Roku Streaming Stick 4K is designed to be compatible with any TV that has an HDMI port. This means it will work on both smart and non-smart TVs, as long as they have an HDMI connection.
If your TV is analog, don't worry! You can still use the Roku Streaming Stick 4K by using an AV Composite Converter. This will allow you to enjoy all the features of the Roku Streaming Stick on your TV.
All Roku streaming players will work for any television with an HDMI connection, so any Roku player can be connected to a 4K UHD or HDR-compatible television. However, to stream movies and TV shows in 4K UHD or HDR you will need a compatible Roku streaming player and television that supports 4K UHD or HDR. Jul 24, 2023
Rokuhttps://support.roku.com > Roku setup
Jul 24, 2023 - From a USB port on your TV Any Roku Streaming Stick supports USB power, but only some Roku players do. If you are connecting your Roku device ...
5 days ago - Guided Setup · Insert batteries in the remote control · Turn on the TV · Choose a language · Select a country · Select home use · Connect your Roku TV ...
https://my.roku.com > signup
Support home; Before you buy; How to: Using your Roku; Account, billing and orders; Setup and troubleshooting; Community. Activate a device.
All you have to do is locate a Roku device where the outputs are configured for the inputs on your set. If so, you are good to go!!!! Of course, you do have to have a wi fi network for your Roku to connect to
if the tv has no hdmi socket then you are wasting your time
the one way you may get it to work is to buy a set top box to convert signal to hd as they have a hdmi socket in the back
Forgive me I am out of touch with modern techno stuff but I think this is some media streaming gizmo if so then your TV would need possibly HDMI or at least a 15 pin svga port found on flatscreens. Most older TV's would have an aerial socket, scart and phonos of one sort or another (with the odd BNC and DIN type thrown in).
Now if this is so, I doubt you will manage it at all your ROKU is chucking images out at a rate that is far beyond any old system to work with. A modulator say those £30 thingys that have a scart or phonos can only cope with basic video or rgb.
Your ROKU would have to "slum" it down to RGB or COMPONENT level before you could get that converted down to say a modulator with basic video by then its quality would be very gone. To understand deeper look for the word Scaler in up and down this is a device to alter images from one format to another found in say TV systems, though for you I would get a more modern flatscreen that has suitable sockets to match your ROKU plenty of say older models with less features than their newer cousins and have still older style connectors for older secondary equipment (video) to work with.
I am working a bit by guesswork over what you have there to work with, some convertions are easier less complex than others.
Hope this helps a little.......
I always get the 3 because it has the most features. I have three of them now, and they all work great. I think any of them will work with your tv as long as it has an HDMI input.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://electromedicals.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Glenda, Are you connected to your tv by HDMI or AV cables? The blue screen is usually an indication of one of two things. 1: The HDMI cable has come loose but not entirely disconnected (Turn off Roku and TV unplug the HDMI cable from the Roku AND Tv and reconnect them making sure to seat the ends securely and turn on TV and Roku in that order) 2: your TV or receiver may not support HDCP (a content copy-protection
solution) over HDMI. This is generally true for older TV models that
have early HDMI implementations that do not follow current
standards. Try connecting your player with the included A/V composite
cable instead.
Make sure you select the correct input for your device. If you are using RCA cables then select the RGB option on your inputs, or it may RCA as a connection. If you are using HDMI then make sure that is selected.
