Question about Casio Sea-Pathfinder SPF40-1V Wrist Watch
Set alarm on casio path finder watch
How to set alarm function
Posted by John F Donlon on
jamulder513
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • Casio Expert
  • 141 Answers
Posted on Oct 17, 2016
How to turn off the alarm?
http://www.freestyleusa.com/support/
the second window down has the buzz instructions.
in the buzz instructions
TO TURN ON/OFF THE ALARM AND
HOURLY CHIME:
1. Press S3 button to select HOME ALARM or FOREIGN ALARM to set. 2. Press S1 button to activate the alarm. Alarm indicator /
will appear.
3. Press again to activate the hourly
chime. Chime indicator will
appear.
4. Press the third time to activate both
functions. Both of the indicators
will appear.
5. Press fourth time to deactivate both
functions. Both indicators will
disappear
May 30, 2014 | Freestyle Shark Buzz Wrist Watch
Alarm setting I want to set an alarm to repeat daily as a alarm clock would for a g shock
casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left ...">casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. ...
Mar 10, 2011 | Casio Watches
I need it to chime every hour on the hour
You should be able to set this up in the Alarm function.
Set the alarm time to say 12.00 and then the ringer function to the bell shaped symbol and that should do it.
Dec 09, 2010 | Casio Edifice EFA109-7AV Wrist Watch
I just bought a Kenneth Cole Unlisted mens watch. There is no instructions on how to set the day and date. Is it broken out of the box or are those dials just fakes? Jens
The Mode button on the bottom left hand side will set your "SET" buttons to work.
The first push of your Mode button will activate your Stop Watch. Press the top right button to time your subject. Press it again to stop timing your subject.
Pressing the bottom right button will reset your Stop Watch to zero.
Press the Mode button to release your Stop Watch function and return to the Telling Time function.
Press the Mode button twice and you'll be able to set your Alarm function. Your Hour number will be flashing. Press the top right button to set your Alarm Hour. If you Alarm Hour is for the afternoon or evening continue pushing until a "P" appears by your hour number . This will be your afternoon/evening hour. If there is no "P" that, of course, will be your morning hour.
Press the bottom right button to adjust the minute number of your Alarm function. Your minute number will be flashing. Again, using the top right button, you'll be able to adjust your minute number.
(If you hold any number changing button for a long time, the numbers will flash through rapidly.)
Press the mode button to release your Alarm setting function.
Press the Mode button three times to set the Time of Day on your watch. At this point you'll also need to push the bottom left button to activate your Time of Day function. after pressing the bottom right button your minute number will start flashing. Press the top right button again to adjust your minute number. Once that's done, press the mode button to release your time of day function.
Hope this helps!
Oct 18, 2010 | Kenneth Cole Watches
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
How do I enable the alarm on the Eddie Bauer world travel clock with flashlight? I can set the alarm time but I do not know how to enable it. I set it by 2 minutes ahead of the current time and waited for...
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
Dec 24, 2009 | Eddie Bauer Watches
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
Can't set the alarm on a pulsar pf 3681
Pull out the time stem to the first notch. Use the bottom button or reset button to change the alarm.
Dec 22, 2008 | Pulsar 100 Meter Alarm Chronograph PF3277
Casio Sea-Pathfinder SPF40-1V Wrist Watch Logo
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Bruce Robin
Are you a Casio Watch Expert? Answer questions, earn points and help others
