So not sure if I should replace the led strips or replace the inverter...i only want to do this once
Mark,
Try this first. Not sure, but most Vizio menus within the last 4 years should be close enough to navigate through. It's a little tricky to get to. You highlight picture, then you hit the right arrow to bring up the Picture menu. Go down to Advanced Video (one above Reset Picture Mode) and hit the right arrow again to bring up another submenu. Go down to Backlight Control. There are three options: OFF, DCR and OPC. Both DCR and OPC seem to cause a problem. Try turning this feature to "OFF" and see if the the problem goes away
Testimonial: "the screen is black and when i hit menu i cant see it to navigate through"
the screen is black and i cant see the menu
Mark,
Sometimes the following action will discharge any residual build up of static on the backlight circuit board.Turn the TV off and unplug it. Press the power button on the side of the TV for 30 seconds. Let go of the power button and plug the TV back in. Turn back on. Can you see a screen now?
If not, I think I've gone as far as I can to help you. You'll need service. I'm not a qualified tech but throughout the years, I've heard of and learned a few tricks. Hope this helps.
BTW, how old is your set?
